ATP turbo kit w/SSQV vids
sounds good. i saw some of your other vids up there..that GLI sounded broken with the HKS..
just out of curiosity... does the car blow any smoke ??
i know seceral ms6 ownwer with the cp-e DP blow a lot of oil smoke.
i was just wondering if this is fixed with a better turbo.
i believe it is the turbo blowing oil and not the engine itself.
Sounds like weak seals.
I have not noticed very much smoke at all, just on cold start-ups I will have a little grey smoke.
I do have the HKS going recirc, mostly because people have actually been dyno'ing lower running vent to the atm than recirc. Why, I have no clue, but its enough suspicion to make me stay recirc. I could hear it very clearly with my comp's sound system, but your right, it isn't THAT loud.
On any vid that I am out of 1st gear I would hit feul cut if I went WOT, so most of those vids are me at like 13 psi and 70% throttle, trying not to hit feul cut. I just recently got the ATP feul cut defender and said goodbye to feul cut. I'll try to get some vids of me going WOT and take my recirc hose off the HKS.
how much the ATP fuel cut run you?
it will work on the ms3....but first you need a turbo that can efficiently make more boost. the stock k04 is maxxed out from the factory.
Were gonna find out just how maxed out it is.....(blowup)
