Update: All repairs will be covered as "good will", but I'll still owe the diagnostic fee.
Hi everyone,
I came here to vent my frustration with the dealer and to see what you guys think..
I dropped my car off at the dealer today to have him address a number of issues before my 36,000 mi bumper-to-bumper warranty runs out. And I an not happy with what they told me over the phone.
Here are the issues:
1. Vibrating mirror (TSB, dealer will order parts)
2. Creak/squeak when going up driveway at an angle (TSB, dealer will fix)
3. Drivers seat lowering itself over time (TSB, dealer will order parts and fix)
4. Clutch pedal has 1.5"+ of free play (dealer says it's an adjustment item.. will not fix under warranty)
5. Air blowing out of foot vents with only the dash vents enabled (dealer says it's an "adjustment item".. will not fix under warranty)
6. Squeaky shift linkages (squeak when shifting into reverse and 5th) (dealer says it's a wear item.. will not fix under warranty)
7. Squeaky/sticky slave cylinder.. dealer says he can't replicate the problem despite a video I gave him clearly showing the issue
8. Squeaky drivers side door lock actuator.. dealer says it's normal.
Dealer wants $535 for labor to "adjust" the clutch pedal (which has no adjustment on the CX-5), "adjust" the air vent knob (which also doesn't look like it has any adjustment) and lube the shift linkages (which should have been lubed at the freaking factory)
I stupidly agreed to a $95 diagnostic charge when dropping the car off for the clutch related issues because I was certain it would get covered under warranty anyway.
I contacted Mazda USA. They gave me a case number and said that they would call the dealer to discuss the issues.
Hi everyone,
