- 2011 Mustang GT
I've heard that too, but when you first install it, you 'flash' it, then I don't believe switching maps is the same as flashing in the eyes of the ECU.
"Stage1+SF 93 " What does the "SF" in this map stand for? (Yeah, I'm a noob).
Also, I am getting more boost cut than I would like to tollerate. I'm running the Stage 1 MSCAI 93 map. Do you guys think I might get less cut running 91 octane map? Also, if I run 91 map and put in an occasonal 93 is that a problem?
Thanks a ton!
For the purposes of the AP, does the AEM CAI with straightener count as the MSCAI?
I heard a rumor that our ECU's could only take 100 flashes in a life time. Anyone find that to be true?
Romping on it immediately after an AP flash isn't a good idea. I always go easy on it for the first 150 kms. or so (about 100 miles) before I even consider digging into the throttle much and even then, I get on it slowly for a couple of more days before I go balls to the wall. But I admit, it's really hard to resist not going WOT even for a few days in this car!
From my experience, the most aggressive map I've tried was the Stage1+SF 93 octane v1.03. This map made my car feel like a dog in heat - spikes to 22/23 PSI and holds 18-19 PSI and subsequently got me into boost cut territory and increased KR which I didn't like. I'm currently on the Stage1+SF 91 octane map and things have calmed down a bit, I'm still seeing 21-22 PSI peaks and hold 17-18 PSI with the rare boost cut once in a while but KR is being held in check. Will be getting it road tuned probably in a couple of weeks and hope to see good results.
You can certainly run 93 on the 91 map.
Pretty much all cars that require Premium fuel from the factory are tuned to run on 91 anyway. (dunno)
