scatt nasty
Banned
- 08 Metropolitan Grey Mazdaspeed 3
Well got my AP today and loaded the only map that seemed somewhat suitable to my mods... the MSCAI/TBE map... This map is awesome but definately won't stay loaded for long.. (at least until 1.03 come out) It somewhat solved my boost cut issue. I did some runs and 1-3rd gear WOT are ok. Boost stays at high 16-mid 17 and AFR's are good/very minor to no knock, but the car stutters at around 5k in 3rd, like its trying to boost cut(Plugs maybe?).... Once I shift into 4th, by 4600 RPM boost is hitting 18.6ish and then it cuts.. At the time of cut though my AFR's are around 10.3 which is good...I was getting some crazy backfires, sounded like my damn Rem700 .308 echoing through the forest. Before the AP any gear 3rd or above, WOT would instantly equal cut.. so this map is somewhat better, should suffice until the new ones come out (I heard a rumor theres an upgraded TMIC map!!)
I dont think my fuel pump is at fault due to my gnarley AFR's, but hey upgraded internals and 1step colder plugs never hurt anyone right ? Im considering the CPE SRI as well since it will be more map friendly with the AP.Right now I have 3 choices if the new AP maps let me down... Sell AP and get standback, run a MBC setup at 17PSI and clamp it, (this would solve my cut issue and would only be ran of course with upgraded internals/plugs) ORRR Take my DP back to stock and just run some other non TBE AP map.
Give me some suggestions or something.. Im bummed (shrug)
