astriuminc
- CX-9 2013 AWD
need to check if the ECU fuse is blown
thanks in advance....
You failed the state inspection? was the check engine light on? You should have taken it to the dealer, the inspection is free and if you fail emissions the warranty on that is 8 yrs and 80k on emissions controls
Thanks for the follow-up. Can you tell us whether these 4 oxygen sensors were replaced under Mazda's emission warranty? These 4 oxygen sensors with labor can be very expensive if we have to replace them by ourself!just to help any fellow CX-9 with the same issue in the future, I failed emissions due to a bad oxygen sensor but there was no check engine light or any codes, I swapped out all four oxygen sensors and the emissions monitors became ready after two drive cycles
I highly recommend getting one of these and make sure monitors are ready before going for emissions test:
https://www.amazon.com/dp/ (commissions earned)
this is not good guys, I failed emissions too !! this sucks, need to get this to pass in two days or my inspections sticker expires,
no check engine light or anything, just failed for monitors not ready, engine has been running rough during heavy acceleration, I can feel the whole front shake. I was stupid, should have used a cheapo OBDII reader first before going to inspection station
today, now it's too late, already in the system as a fail, now have to trouble shoot or take it to stealership, out of warranty 112,000 miles. Going to try astriuminc's post and get some cheap O2 sensors off eBay and swap them out myself, keeping my fingers cross.
