Anyone interested..??
wwest
I went by the Kirkland Mazda dealer today to look over the CX-7 and collected a brochure. Before I actually buy one to experiment with/on I was wondering if anyone in the Puget Sound region might be willing to participate in an experiment to improve the FE of the CX-7, possibly substantially so.
What I would like to do is mill the head of a CX-7 engine to get a compression ratio of 12:1. 12:1 has become typical for a DFI, Direct Fuel Injection, engine, but since the CX-7 is turbo charged the factory's "native" compression ratio is, as it must be, quite a bit lower in order to provide for the additional "compression" from the turbocharger as it spools up.
During the experiment the wastegate would have to be "wired" open so the effective compression ratio could not rise (much) beyond 12:1.
If anyone owning a CX-7 is interested I would be will to pay the costs purchase and install a new factory head once the experiment is complete.
I suspect the off-boost FE improvement might be in the range of 50%
Be careful though...the 6-spd auto trans is the weak spot on the CX-7 when it comes to power mods should anyone take that and run beyond that.
Under my "plan", with the wastegate "wired" open, the peak power would be reduced. The experiment is to find out how much the FE would improve without lowering the power band all that much.
