Anyone here bought a built engine from protegegarage.com?
c7scayman
96 Mazda Protege DX 1.5L
I am wondering the the built engine is actually more reliable. I was dissappointed when I read that they are only safe up to 12psi, which is around 220Hp I believe. A $4000 engien should offer more potential than that.
Anyone here has experience with them?
speed circuit also does built engines.
personally, unless i lived within 30 minutes of their shop, i wouldn't do it. the engine is too integral to the car not to have it built by a shop that is close by.
my suggestion: if you want a built motor, either do it yourself, or have a local shop do the work for you.
This. Most any engine shop will build you a engine. They can get any parts you want to put in it.
my car has a built engine from Ken at Protegegarage but I have no clue what has been done to it since he sold the motor to another guy and now i own it. I heard about 400hp on my motor but now sure, still boosting 6 or 7lbs. Dont want to risk and boost more might blow the motor.
um..... (uhm)
a built engine with a good tune should be able to handle anything u can throw at it. i dont see a point in having a built engine and only boosting at stock levels. if you have a built engine make sure u have supporting mods (fmic, tbe, dp, intake, boost controller) and something to tune with either a standalone like haltech or at least a piggyback llike ssafc. with supporting mods and a good tune on a piggyback u can easily boost 14psi on a stock t25.
welcome to the forum!! Just so most of you know, Ken doesn't build any motors. Hell, he doesn't make or supply any parts for that matter. He is strictly a middleman for everything on his site. His built motors which aren't his, are built by Dino at SC as far as I know. Same thing with SU. Speed Circuit does the builds. They are both middlemen. As far as built motors and boost goes, you aren't going to blow a built motor on stock boost, hell not even 10 pounds. With solid tuning, that motor will handle whatever you throw at it. But, then the transmission becomes the limiting factor. A built motor can handle more than 400. Everyone just says that because a specific vendor listed a certain rod at 400hp, but that was only said because that is already more than what the stock transmission can handle. So, to clarify things, on a built motor, you are limited to the 300-400hp range due to the limitations of the stock transmission. But when you add a built transmission to the equation along with a good quality LSD, you have then removed that limiting factor and your potential for more power become a lot higher...only limited by how deep your pockets are in the event something happens later on. I wish people would understand that instead of following the he said/she said crap about hp levels with built motors. Bottom line, K1/Molnar rods can handle way more than 400hp. Pauter rods can handle more than 700. The 700hp figure was only listed because a built FS in a 323 managed to make over 750hp. That doesn't mean it's limited to that power level. The true potential of either rod has never been tested on the FS platform so honestly, there shouldn't even be any HP numbers listed for these rods. Tuning is the important factor on saving a motor from that dreadful moment. You can't predict how much power a stock or built motor can handle. It's stupid, people have said this crap for years now. Nobody knows because nobody has deep enough pockets to take the car to a level close enough to test the true potential of a built motor. Everyone's info is based off of what the next man said. Just like stock motor potential. Everyone used to always say "stay at stock boost levels" you will blow. But yet, people have turned up the boost and had no issues. Now, everyone says don't go past 10psi on stock internals. But yet, it has been done numerous times with no ill effects. Prime example, 505 made 277 on stock motor and today, that same motor is still running strong in his car. and of course we all remember the guy with the silver protege that boosted 14psi on a t28 for a couple of years before wrecking the car. Yes, he was using methanol, but it is possible. People need to stop following up other peoples assumptions. Im guilty of it, but I no longer do it. If my car wasn't wrecked right now, I'd be running 7-8 psi on a gt30 ON STOCK BLOCK until I built the motor. It's all in the tuning and how you care for the car. If you are smart about it, it will last. If you are dumbass and boost all day long from light to light, stop sign to stop sign, the car will not last.
welcome to the forum!! Just so most of you know, Ken doesn't build any motors. Hell, he doesn't make or supply any parts for that matter. He is strictly a middleman for everything on his site. His built motors which aren't his, are built by Dino at SC as far as I know. Same thing with SU. Speed Circuit does the builds. They are both middlemen. As far as built motors and boost goes, you aren't going to blow a built motor on stock boost, hell not even 10 pounds. With solid tuning, that motor will handle whatever you throw at it. But, then the transmission becomes the limiting factor. A built motor can handle more than 400. Everyone just says that because a specific vendor listed a certain rod at 400hp, but that was only said because that is already more than what the stock transmission can handle. So, to clarify things, on a built motor, you are limited to the 300-400hp range due to the limitations of the stock transmission. But when you add a built transmission to the equation along with a good quality LSD, you have then removed that limiting factor and your potential for more power become a lot higher...only limited by how deep your pockets are in the event something happens later on. I wish people would understand that instead of following the he said/she said crap about hp levels with built motors. Bottom line, K1/Molnar rods can handle way more than 400hp. Pauter rods can handle more than 700. The true potential of either rod has never been tested on the FS platform so honestly, there shouldn't even be any HP numbers listed for these rods. Tuning is the important factor on saving a motor from that dreadful moment. You can't predict how much power a stock or built motor can handle. It's stupid, people have said this crap for years now. Nobody knows because nobody has deep enough pockets to take the car to a level close enough to test the true potential of a built motor. Everyone's info is based off of what the next man said. Just like stock motor potential. Everyone used to always say "stay at stock boost levels" you will blow. But yet, people have turned up the boost and had no issues. Now, everyone says don't go past 10psi on stock internals. But yet, it has been done numerous times with no ill effects. It's all in the tuning and how you care for the car. If you are smart about it, it will last. If you are dumbass and boost all day long from light to light, stop sign to stop sign, the car will not last.
^^^^^ thank you good sir (2thumbs)
haha, no problem. Just edited my post by the way
yep i noticed lol. its just funny that even after all the posts and threads over the years about the same topic, people still make these assumptions. granted people may be noobies sometimes, but thats what the search button is for on the forum and all the stickys and how-to's
i talked emailed Ken and he said he was the one who built it. So i dont know, he probably stopped building them, but he said he did built the one i had.
from the build i think he deleted the VTCS, i couldnt find it anywhere above the manifold. either that or he rewired it somewhere, but the code for the VTCS keeps coming up.
the built engine costs $4000? i wouldnt by that thing, as far as the parts go building your own engine will go around $1500 or so, i was thinking of building my engine myself so i looked into it
