Any way to reduce shaking?
do you mean engine lash, you need tog et a AWR motor mount $74 shipped
would just the front mount be sufficent? Im not incedibly knowledgeable about how to get to the back one, and be able to replace it.
Make sure not to rest any babies on your engine while it's shaking :D
Front motor mount rules, engine doesn't shake rattle and hum anymore
do you guys have the a/t or m/t one?
but will the shifter still rattle, along with the seat, dash, steering wheel, and the whole rest of the car?!?
you will notice the car rattles when cold at around 900-1200 rpm's after that you can hardly tell
Why would a header make the car shake. I would think it would lessen vibrations since it frees the exhaust out easier.
Or hey, my car shaked too when I first got my HKS, but now its either gone or I've got used to the vibrations.
yeah, my car shakes so bad after the header install that you can actually see the door flex and vibrate. i thought that the engine mounts just translates more of the vibrations to the frame of the car, causing even more vibrations in the cabin? this isn't true?
im with tonkabui... The reason iv heard for the motor mounts are to reduce engine "spinning" (my term for it) and putting that power lost toward the wheels b/c the mounts are more stiff
i have the same shake and hate it --- i just havent had time to take the header off - since noone cant get it to stop --- corksport said they can try a few things -- but i dont have money to throw around for some one to trial and error on ---
it could be $40 bucks or after hours of trying things it could be $300 ---
it Sucks Azz :(
Wwing49 said:
I heard AWR Just makes the "engine lash" worse.
the front AWR mount does a great job in eliminating the engine lash. causes more cabin vibration between 700 and 1000 rpm's but keep the engine from moving!
Yea, i guess when i was saying engine lash, i meant cabin vibration. The damn shifter visibly shakes, well its actually just blurry b/c its moving so fast
gives your car an intense feeling on idle as some of my women friends constantly tell me (thumb)
