Any suspension changes with the 2022 CX-5?
I had a chat with Megan Racing about their front stabilizer bar (CorkSport doesn't offer any of these for the CX-5) to find out why they list 2013-2021 for the applicable years and excluded the 2022. I got back sort of a "maybe" answer that it might not work due to a camber change (why that could impact it I'm not so sure). Anyway, the guy suggested I check with the forums and that's what I'm doing.
Has anyone heard of any change to the suspension in the 2022 vs the 2021?
Anyone that has a 2022 swap out their front stabilizer? FWIW...I know of a manufacturer for the rear for a 2022 AWD.
I would like to think the fronts should still be the same. I am more interested in upgrading the rear on a 22 turbo awd as 18mm is a bit on the small side.
I haven't driven this thing hard enough to know for sure after my suspension swap (rear springs now at 7kg/mm = 392lb/in). I do have that adjustable camber upper control arm to install and that would be a perfect time to upgrade the rear stabilizer!
What kg weight did you go for the front springs on your coilovers?
8kg/mm or 450lb/in.
It isn't overly harsh, but really, 6-7 might be a better choice.
Note that I think the rear rate seems about perfect with my shocks set on level 4 (1-16 adjustment on these).
