Antifreeze/Coolant
SP33D
Black Mica MSP
My coolant is on the Low line... so I bought some more coolant to fill it.. but is it ok to fill it, or should I drain the old fluid first?
i think it is ok to just add it. You may wanna think about adding water wetter, it will help keep the temps down.
if you didnt buy premixed stuff you should mix the coolant 50/50 with distillled water, then just top it off
Just top it off.........
Why is it low......
Make sure you mix it if it isnt already.. Someone else mentioned that but not a lot of people know you need to mix it..
