I've got a TWM short shifter installed on my '03 P5 and noticed today there is an awful lot of side-to-side play while in gear. I've done some Google-Fu and searched the forum and everything is pointing to replacing the bushings.
The set that CorkSport sells (4) and the set that TWM sells (2) are apparently all different, with there being a total of 6 bushings. I don't think the CorkSport set fits the TWM shifter so I'm leaning towards ordering the TWM bushings, which I believe install on the transmission end of the linkage.
I'm planning on crawling under and taking a look around. Is there an easy way for me to tell which set(s) is/are bad so I know what I need to order?
