2017~2023 Another question on adding LOC, AMP and Sub (CX-5)
Hi, I have a 2022 Non bose CX5. Hate the sound system and planning on upgrading.
Read through multiple post and guides and just have a couple of questions.
I am planning on upgrading the door speakers and tweeter in the future.
Right now planning on adding powered sub, amp & loc.
Planning on getting the LC7i, 4channel amp ( 1 to front, 1 to rear & 2 for sub).
From my understanding, you have to tap the wires from TAU to LOC to Amp to speaker & sub.
My question will be, will the amp be able to get power from the LOC?
I do not have any sub, so will LC7i be able to get bass into the sub?
Also can the amp power the powered sub?
Lastly how do i connect the amp to the speakers? Like where do i bypass the factory amp?
Any advice will be appreciated. Thank you.
South Carolina
12 MZ5 13 CX-5
I'm assuming you mean remote control power to turn the amps on. Yes it provides that. However, the amps themselves will still need a heavy gauge power wire ran all the way back to the battery.
It absolutely will provide an RCA output specifically to run a subwoofer. The LC7i doesn't have a built-in crossover though, so you'll still need to use either a DSP (recommended) or many amps have their own built-in crossovers. So that's not really a huge issue.
No! A powered sub already has its own internal amplifier! There is no need for an extra amp in that case! You only need an extra amp to run a traditional non-powered sub.
I wasn't aware that the standard stereos even had an outboard amplifier. But, here's how this guy pulled it off. You'll need a PAC AEOM-MAZ2 t-harness to keep from cutting any factory harnesses. That interface will come with it's own little blue LOC. Don't use it, because you're using the much superior AudioControl.
Upvote 0
Thanks for the update. Think i am going to leave it to the professional. Feel like too many things may go wrong
Upvote 0
