Android Auto Error 13 due to wrong system date (year stuck at 2045)
Hi everyone,
I own a Mazda CX-5 2022 (US version) and recently ran into a strange issue with Android Auto.
Problem description​
  • When I connect my Android phone, I always get Error 13 (communication error).
  • The system clock in my Mazda shows the year 2045.
  • Because of that, Android Auto refuses to connect (Google requires correct date/time for certificates).
  • Apple CarPlay works fine with an iPhone (so the USB port and cables are not the problem).
  • I tested with 3 different Android phones → same issue on all of them.
What I have tried so far​
  • Tested multiple cables (including certified, data-capable ones) → no effect.
  • Performed a factory reset of the CMU → year still stuck at 2045.
  • Updated CMU firmware to the latest available version → no change, year still 2045.
  • Tried setting time via GPS sync → it always 2045.
  • In the menu, I can only adjust hours/minutes, but not the year.
  • Disconnected the battery for 30 minutes → no effect, the year remains 2045.
My suspicion​
I live in Ukraine, and during Russian missile and drone attacks, electronic warfare (РЕБ) is activated in our region.
The issue appeared exactly after one such event. My suspicion is that the RTC (Real Time Clock) chip inside the CMU was damaged during the interference, which is why the system clock is stuck in 2045.
Current status​
  • CarPlay → works fine.
  • Android Auto → always fails with Error 13 because of the wrong date.
  • Factory reset + firmware update + battery disconnect → did not solve the problem.
Has anyone experienced something similar?
Could this really be a failed RTC module inside the CMU?
Is there any known fix besides replacing the whole CMU unit?
If anyone has ideas on what else I could try before replacing the CMU, I’d be very grateful.
Thanks in advance!
Hi everyone,
My suspicion​
Current status​
Thanks in advance!
Hi bro! I have had the same problem starting from yesterday. I'm also from Ukraine. I changed the date from the Engineering Menu in the chapter related to Navigation. When the display rebooted, I could access Android Auto. But after the engine was stopped, the problem turned back.
I have contacted the Official Mazda service today. They responded that this problem has widely happened in Ukraine. Official services are thinking about how to resolve this issue.
Hey guys) Found your question while searching for solution of the same problem. Did all the actions as well before that, so it was a little bit of a time waste :D
Only workaround for now I've come up with is to disconnect the GPS antenna temporarily. For me it's not a big deal - Gmaps and Waze are much more important. It could be done in like 15 minutes or so.
1. Remove to dashboard panels (as shown in the video).
2. Remove two philips (cross) screws holding the screen and infotainment system - it's on the same video.
3. Remove two bolts with 10mm heads holding the screen and infotainment system - it's on the same video.
4. Take the infotainment out, and disconnect the small blue connector (should be on the right hand). There are variations of it's position but connector itself is the same - blue one 1cm*1cm.
5. Before putting all together turn on the ignition and enter service mode on infotainment. First push and hold the Mute, then press and hold Favorites, then press and hold Media (note icon). You should hold all three together for 5sec. Go to Functional inspection/Adjustment - Navigation System Inspection - GPS Date/Time Setting. Done)
Thanks a lot, guys, for your replies!
@daemonkor — I really appreciate your input. I also tried through the Engineering Menu, same result as you: it works until the next engine restart, then everything goes back to 2045. Hopefully, Mazda official service will provide an official fix.
@pioneer_ma — your method really saved me! 🙌 I followed your instructions step by step and Android Auto is finally working again. Huge respect for sharing this — I’ll also send it to our local Mazda CX-5 club, I’m sure it will help many people facing the same problem.
You're welcome, bro. I was struggling for a week with the same problem and your post made me go do something. Hello from Kyiv 🫡
