Amsoil Manual Transmission fluid?
i'm using the gear lube, also known as amsoil MTG. not sure if the MTF will work the same because it has different specs but right now i have 0 problems and it handles heat better than the stock fluid.
do not use MTF....use MTG because that is the correct fluid for our transmission
I have the amsoil mtg in my MS3...works great....smoother shifts and protects the trans better...no LSD whine either
My LSD whined terribly when I switched to Amsoil. And the shifting was worse than stock as well.
I switched again to Redline MT-90, much better.
I've used Amsoil MTG and Redline MT90. I recently switched to Ford XT-M5-QS. It's vastly superior for our cars. I've used Amsoil for 22 years, but the Ford stuff works best. It's just hella expensive.
