JoseProte83
Rotary Power FTW!
- 02 Seabreeze DX
Looking good bro, stretched now?
needs more low....alot more low
my brother just slotted his front struts today, i took a few pics for him...
^front
^rear
You can do it your self in under 20 min. Heres what i did:
1. On the strut/hub, Take off the top bolt. Loosen the bottom one
2. Insert the bit in the top hole, then attach it to the drill.
3. Put one lug nut on and slide a pipe onto the lug nut.
4. Start the drill and pull up on the pipe. Be sure to put some PB or some cutting lube on the bit
Yeah 205/40 on 17x8
its in a 17x8.5 +25 offset, 195 40 tire, and i dropped it as low as comfortably possible for my struts. need to do some custom work to be able to run like shavi in the front. I bought the wheels from a dealer that made them for the xB in that size, idk if you can get them in that size anymore, but seeing as they're rotas, its possible lol
I used this method. took a vid as well. but stupid youtube wont load. I can try again later. at work now.
would you happen to have any full/close up shots of the tire/wheel combo.been considering that tire size.
Don't do it....sorry kauai....but my brother just showed me a set of redrilled salad shooter for sale locally....for cheap as ****
we may have to be twins
