aftermarket MAF?
well i had an AEM short ram intake in and over the course of 5k miles my check engine light came on and my MAF is all thrown off becuase of the increased airflow...but where can i pick up an aftermarket ECU?
you can get one off an MP3 or get an apexi AFC ecu.
the sri shouldnt throw out the maf! the sri wouldnt be the problem otherwise almost everyone would have the same issue...
when i brought it to mazda they claimed the sri was the cause of my idling problems(my MAF)....so i dont kno maybe there just tossin me around or whatever
That will not work on our cars due to the voltage problem with the MAF.
uhh ok...
let's talk out of our asses and say "get a miata maf", "get a mp3 maf"
WHEN THEY'RE THE ******* SAME
What the hell?
It has been proven the S-AFC will not work on the Protege. And the MP3 MAF is the same as the Protege 5 one.
The only "after-market" MAF I have seen is the one MPNick sells. It's an 80mm MAF and is really only good for F/I, according to MPNick. It is worthless for just an intake.
TheMAN said:
uhh ok...
leave it to mr.additude to try to start a flame. Go back to protegeclub "Protege all knowing master".We dont need your smartass information. Get a life!
:rolleyes:
I think his response towards flame is about equal to the BS people have posted in here.
And P-Club is a ghost town. Club Protege is the new place to go.
really, did it help the thread originator?? Did he have to use that language?? Did the people that are trying to help him deserve that type of treatment??? Quick answer NO:rolleyes:
SpicyMchaggis said:
i love you ghost.
people here kill me. Just because they know something, they think they can just come in here and bully people that dont. How can people learn anything like that. Its BS and it should stop.
Now back to the regularly scheduled program....:D
what does the apex s-afc do? ive seen it in magazines but had no clue what the deal with it was
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air- flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %
Does the BS that has been posted help the originator of this thread?
In one word: No...:rolleyes:
Sure he could have said it differently, but the people spreading BS shouldn't have said anything. That would have prevented the offending response.
