After break-in...
eeveyl
I've been told by a few friends that I should change the oil on my MP5 after I finish the break-in period... but my dealer told me I don't need an oil change until 5k miles. So... obviously, changing the oil early won't hurt, but will it really make a difference?
Also, should I switch to synthetic, or keep the regular stuff?
Thanks!
I think that you'd be jsut fine if you wait to the recommended 5000 miles. I did my first change at 3,000 with regular castrol. I'll go synthetic on my next oil change.
On the other hand....on my GSXR race bikes. I tend to do my first change at 200 miles, my second at 1,000 during break in. Of course I use the crappiest oil you can buy until I run her on the track and then I use $14/quart Maxima 0w-30 synthetic.
I posted on another thread that already closed about just this thing. It's up to you.
Traditionally, the reason to always change during break in was to get out microparticles (and not-so-micro-particles) that remained in your motor from manufacture. It's the same reason most folks here still change every 3 or 4K. When the motor is made, there are little bits of stuff that wear the motor. draining the motor shortly after (1K or so) gets those particles out before they have a chance to do some damamge.
And as you run your motor through its life, more particles will appear. What neither the oil companies nor the car companies will tell you is that it's not just about how long the oil remains viscous and effective as a lubricant, but how much "stuff" is building up in the motor. The synthetics retain their lubricating qualities longer and in more extreme conditions (sometimes) than dino juice (regular). However, just as many particles are entering your motor. The car companies have made motors that do indeed "last longer," or have the potential to. However one must remember that is in their interest as far as marketing goes to have a car that lasts a long time, and doesnt need as much maintenance, at least on paper. Our mazdas are definitely capable of going well past 3k without a change (up to 7.5k, according to owner's manual), but I and many people on this site dont risk it.
You'll find that people who drive their cars into the ground, getting 150, 200, 250k miles out of a motor change religiously at 3k.
Just my 02, and remember that if it says it's cool on the manual, then maybe it is.
Either way I would recommend a break-in change. and go ahead and use a cheap dino like jhafti said. Then switch to good stuff.
I just changed mine at 2100mi. I will change it every 3k miles from now until I sell the car. Mobil 1 Synthetic seems to work well for me. I did the same thing to my Focus at 1500mi with no ill effects.
I know a guy who bought a 2000 Miata knowing NOTHING about cars. So he washes and vaccuums it regularly, but when I asked how often he changes his oil he said he'd done it two times... once at 15K and just recently at 22K... I asked him to start the car and low-and-behold it burns oil... with less than 25K miles!!!
So changing at 3K or 5K or even 7K probably won't matter... but please people, do it before 15K miles!!!
Mobil 1
I know its kinda expensive but mobil 1 oil and filter is the best.
I work at autozone and all my co-workers tell me i should use it.
but if you do go syn. you have to stay with it, cant switch back.
also with mobil 1 you need to use their filters too from what i hear, if you use anyother filters it tends to leak, dont know why but im not going to risk it. Mobil 1 is supose to leave less strain on your eng, thus a longer lasting eng, plus if you do performance things to your car. It would help too.... not performance wise but the life of your eng.
thats my opinion.
Re: Mobil 1
thats my opinion.
Mobil 1 is good. Also AMSOIL and...i forget the other one. Mobil 1 works fine with other filters, PureONE or AMSOIL filters are the highest rated.
But you certainly can switch back to standard. Lots of folks do it who race their cars, switch back and forth.
But yer right, everyone here should take a look at Mobil 1
