The map I have now is rich as hell.
You should compare your map to my map to see if the values in mine are lower than yours before you load it.
CustumMSP,
SSAFC map with 440 injectors, Disco gt28rs, and walboro and a a full page listing all other mods.
I am going to try your map right now. I have had zero luck tuning this car
Would you consider this a moderate to safe tune? It just seems the even with all 440 maps the AF ratio doesn't want to drop under boost. I have my Aeromotive fuel regulator set at 42 psi base pressure, with the hose disconnected.
The ecu always finds 14.7:1 at idle, according to my wide band; however cruising and " light! " throttle make the af go to 13.1 ish at 10 in/mercury. then stays at thirteens into slight boost. The best luck ive had was adding fuel up 5% to the the so called "super stock map"
My Exhaust gas temps never go above 1100 F which in my opinion is very safe so its hard to believe that I am indeed running LEAN.
When our cars buck under boost.... can that be from running too RICH? or is that just a LEAN situation.
Your map is loaded and ill be back with feedbackin a few
Would the muffler silencer perhaps be messing up my O2 and wideband readings do too less flow rate? It is the typical N1 style 3.5 inch silencer.
I'm starting to become convinced that something's wrong with my afc. Running the supermap. I'm now getting 10's on my wideband even in partial boost...even at 2-3 psi. This isn't even in complete WOT. When we installed it back in August of 2008, I got 11.6 at wot. When the winter came, the ratio went to 10 at wot. I asked around and people said that the change was due to the colder temps. However, throughout this summer i noticed that the wideband still read 10 at wot.
Any of the gurus care to comment?
it used to work great. last summer i was getting 11.6 at wot....this summer all i got was 10 at wot. Pretty much the same weather, etc. Why such a big change?
I listed my mods within the map, check it out.what mods do you have? since its called 440T3T4 im assuming you have a t3/t4 turbo?
im planning on running a T3/T4 setup with 440's so i guess your map will be a great starting point, thnks!
