Ok, I get it now, thanks. Judging from the pictures on a vendors website, the V2 would be referred to as PSC1 with data logging while the V3 would be the FTC1 with timing adjustment and data logging, and the boxes are different looking from each other.the v3 is just the one with the ability to adjust timing, the v2 doesn't.. really they are different units, but people just call them the v2 (w/o timing adjustment, but with datalogging) and the v3 (with timing and datalogging)
You can change the settings, but all it really does is hide the vacuum side of the settings from the grid and if you have the super map loaded it will move the first modifications from the 2psi column to the 16.2psi column. If you load and look at the super map, it doesn't modify any settings below 2psi any ways. If you needed to change settings above 16psi then by all means do it, but make sure you set everything up right for the low psi settings too.I noticed if you change the system settings from 'Vacuum / Pressure' to 'Absolute Pressure' you have the ability to tune all the way to 30 psi, but no tuning out of boost. i dont tune out of boost anyway, is this a good way to be able to tune higher then 16psi?
I think you will be limited by the injectors. As the SSAFC wont idle well by itself with anything higher than 440s.
