Adjustable Camber arms.
greatdane68
Contributor
2010 Mazda Speed3
Alright, got a question.
I'm about to put some adjustable camber arms on the wife's '08 3 hatch. I don't see a big problem with the driver's side, but I do see a problem with the passenger's side.
Can someone give me some advise or a tip or two on this? I did my '10 Speed3, and it wasn't as difficult as this one looks.
Your rears are SPC correct? (on the 08) I have SPC's on my 07 and they aren't hard to mess with at all, well i messed with them on a lift, but essentially , get the rear tires in the air and then loosen the small nut closest to the fender, then loosen the bigger nut going counter clockwise will bring the top of the tire in negative and clockwise will bring it out positive IIRC.
Man, I know how to adjust them. I have them on my Speed3. What I'm asking is how did you get around that top bolt on the right side? Where all the fuel stuff is.
Ninja skills.
See if you can loosen up the parts on the side to get enough clearance to get the bolt out. It takes some work but is do-able.
-Derrick
