Accessport monitoring?
2007 Mazdaspeed 3
Ok wrong section to post I know. Maybe. Before I buy parts I need monitoring so before for I waste money on gauges, does the accessport tell me much? I'll either buy one or just go straight to cobb for tunes since its like 45min away but really I want to know can I check my a/f ratio and my oil pressure on the accessport? Are the values more exact than if I was to have separate gauges? Can I have more than one value displayed at a time constantly while I drive? I don't really know much about accessports at all besides you can flash maps and they are married to your car.
Any help at all would be great. Thanks.
I know you can monitor a/f ratio, KR and some others on the Accessport. I had one but didn't use that features because I use the Dashhawk, which would be another option for you.
Oil pressure monitoring would require you to get a sandwich plate and to do the spin-on oil filter conversion.
Yea I hear the dashhawk shows a lot more than the accessport and this who was sponsored by Cobb said he wouldn't get a dashhawk because you have to do more stuff to get the af ratio to show up.
No you can see the a/f ratio...
Only look at the top right one.. the rest are scary numbers..
Unless you are running and monitoring an actual wideband O2 sensor I would take any AFR reading with a huge grain of salt. You can reference it if you'd like but I would not use that as a value to tune against.
