a/c problem
will0899
so yesterday i left my car idling with the a/c on and now its only blowin out hot air. its like if the heater is on.. i checked the refrigerant level and its full. lookin for a quick fix anyone???
Welcome to the forum. There probably isn't a quick fix unless you aren't doing something right. You question doesn't provide enough information for anyone to suggest a fix. It may help if you answer the following questions.
Year of car? How did you determine the refrigerant level is full? Is the compressor clutch engaging, you should be able to hear it if you have someone turn the air on and off while listening for the click inside the engine compartment? Is the ac indicator light on?
Clifton
the car is an 07 mazda 3 2.3l. i left it idling for about 40 mins. the clutch comes on but the ac only blows hot air. i checked the low pressure side with a gauge and its good..
40 minutes of idle speed should not cause the ac to go bad. I'm not sure checking the low pressure side will tell if the refrigerant level is adequate, I think the high pressure side should also be checked. The shop manual has a troubleshooting section that may help determine what is wrong. There is an on line Mazda 3 shop manual PDF, the ac section has a check procedure.
http://www.mazdaclub.net/mz3ws/
If that doesn't help it may be best to have it looked at by an ac shop.
Clifton
Maybe he was in a traffic jam. I have been in several traffic backups over the years that moved maybe a mile in an hour. Usually on hot days with ac on an engine at or just off idle.
Clifton
hehe i left it idling that long cus i was chasing my mother in laws ugly little dog... that ugly thing bit the crap out of me! well i have an appointment at the dealer but thats not till friday!!! and its been over 103 over here, and its not getting better...
that suckssss dude, and the worst thing is the a/c is one of the most expensive things to fix in a car....
the only way to accurately check the amount of 134a in the system is to fully drain/recover the system. are there no idling by laws in your area i can get a ticket here for anything over 5 min of idling
