I have a 93 Mazda Protege that will not start. The engine rotates fine, but will not start. There is a new fuel filter & pump installed, new alternator & battery installed. I have changed the coil & ignitor assembly (ignition module). I can not detect spark at the plug wire ends or at coil wire end. I have tested all wires for resistance and all check out. I ahve accessed the diagnoistic codes and I am getting the code 02 which is for the ditributor or pcm or components. I have tried spraying starting fliud in throttle body and got a limited sputtering or feeble attempt to start, but nothing major. I should have used brake clean fliud, but did not have it at the time. I have voltage at the terminal for the coil & voltage at the terminal for the ignitor assembly. Please give any advice that seems fit to give at this point. I am at a crossroad.
I am a new member, so I don't know how to send to all viewers.
(deadhorse
(deadhorse
