OhSchnapps
- 2001 Maza 626 ES (Black)
Does anyone here own a 626, or at least know a bit about them?
My car has had some idling issues since i bought it. But lately, it has been idling lower than usual.
When i start the car, the rpm jumps up to around 1250-1500rpm, like it should. But then it takes a long time to drop down to idle speed from there, longer than the other cars i've driven. When it eventually does drop back down, it drops to somewhere between 500-750rpm. Is this normal?
And then if i press the brake pedal to shift out of park, it goes even lower. Same if i roll the windows down (or up). Yes, i know that is normal, but it drops a good 50rpm or so for either of those two.
I am not in extreme temperatures or anything, i live in Jersey so that's not really a problem.
What i want to know is, what is a normal idle speed for the 2 liter 626? And if my idle speed is low, what can i do to fix it?
