3m 2 sides tape - Canada?
VPower
Contributor
2003.P5
Hey ppl
Where do you guys get that 3m 2 sides tape?
It's going to be very usefulll! but...where should I go to buy that tape?
Home Depot? Wal-Mart?
And once it's on...can I remove it? I dont have a heat gun...will a hair dryer do the job?(scratch)
try canadian tire
where are you planning on sticking this? it is removable if you scrape it off carefully.
Well, someone may be selling his rear bumber guard...
and I maybe also get some doors sills :)
What do you mean by the fact of "scrape"? I tough the use of a heat gun was essential..
I'm sure a hairdryer would work to a point if you had it on the hottest setting and right next to the tape. after you get the bulk of it off, use an adhesive remover and watch it break down and you can just rub it off. that's if you are planning on removing it.
the adhesive remover just to remove the remaining glue right?
yeah adhesive remover to get the remaining off, or you can soak the tape in it and try peeling it off or using a plastic razor blade to scrape it off, doesn't hurt the paint much. there are many ways you can get it off, just some take longer than others.
