75 shot of nitrous is a big presto. Make sure it's a wet shot.2words said:its very possible to get 225hp, do all that stuff you plan on and a 75 shot of nitrous express. and presto u have a beast
I'm saying once you have built your engine n/a it's going to be advanced in timing and have high compression, thus, you will need a wet kit FOR SURETurbo Matty P said:I'll stick to my ZEX dry kit...very safe, and a very substantial gain in power.
If you could get 190fwhp N/A for $2500, then people wouldn't spend twice that to get the power from a turbo. I really don't think you'll get 170whp for $2500 N/A either.Turbo Matty P said:<~~~also shooting for 170whp....that should be almost 190fwhp. I plan on using the Perfworks AEM ECU, Wagner EL header, DP, MP, MSP axelback, custom ground cams by Perf.
I think I'm right on target. I'm also looking at about $2500 for everything. should be fun to see. I guess a clutch would be a good idea also!
Are you using a Mustang Chassis Dyno, or a Dynojet Chassis Dyno?Equinox said:well with
2.5" mandrel bent exhaust all the way back NO CATS
Straight through muffler
Catless AWR Header
Fidanza 5.9 lb flywheel
Clutchmaster Stage I Clutch
Injen Cold Air Intake
I managed 150hp, 118whp, from a stock 98whp
The biggest gain was the 11 whp from the header alone
Then to get 20 more whp I suggest
Port match the heads to the gaskets
Polish the heads
Ground out the Valves to 1.5mm over
Replace valves with stainless steel manleys
That's 170hp, 138whp
Another 10whp
Add MP3 ECU
Port match the Intake manifold to gasket, remove and weld up VTCS holes, keep VTCS solenoid plugged in, but not controlling anything (no CEL)
Polish Intake Manifold
Add NGK Extended Reach V shaped Spark Plugs, range 7
That's 180hp, 148whp
Another 5 whp
Add JDM FD-ZE Intake camshaft
Add Mazdaspeed Exhaust camshaft
That's 185hp, 153whp
Another 5 hp + more midrange
Add Tri-point Adjustable camgears, optimize timing
Add AEM Stand Alone from Wagner/PerfWorks, Optimize fuel
That's 190hp, 158whp
Add corksport's high compression pistons - Anyone know the gain on these?
If I think of anything else, I'll edit this post.
http://www.msprotege.com/forum/attachment.php?attachmentid=10021
Equinox said:I'm taking what the dealership says is at the flywheel, and then taking what the car is measured at the wheels stock. 98 whp, and 130hp flywheel. That is my only usage of drivetrain loss, because that IS the drivetrain loss.
That's a whole different thread. I wasn't stopping to question Mazda's rating.PR5Matt said:Are you sure? Mazda did get into some trouble a while back with over-rated Miatas. Though I will admit that the PR5 does feel like 130hp. Though not quite as strong as my fOCUS with supposedly 130hp (stock 110whp). The PR5 has much lower gears than the fOCUS so that helps equal out stock to stock acceleration.
Don't feel bad, fOCUSes range from 100whp-115whp stock, because Ford did not see fit to put a pin or keyway on the cam gears so they are all in different positions from the factory.Equinox said:That's a whole different thread. I wasn't stopping to question Mazda's rating.
