zhoom-zhoom
'24 CX-5
2024 CX-5 under carriage seems very well protected with plastic covers.  Does anyone have issues with rust on theirs?  Would the undercoat be overkill and waste of $?  Thanks.
			Although I’m in Texas and under-carriage rust isn’t a problem. But after I saw many reports on under-carriage rust problem on CX-5, I believe you should do it if you’re in North or Canada unless you plan to trade the CX-5 in several years.The rear isn't covered and starts surface rusting pretty quickly. Exhaust, suspension, etc are what you'll notice first. I have considered doing mine this fall, but I haven't decided if it's worth it yet. Open to opinions.
Rust like that after a few years even with heavy use of salt I believe is unacceptable with today's coatings and materials to look worse than a car that is 13 years old is not acceptable. How can Mazda get away with this? I love how this car drives and looks but also want one that will last. Also very happy with fuel economy so far getting around 30.5MPG on my 100 mile round trip commute.
2005 toyota matrix/pontiac vibe - 225K miles driving 100 miles a day
2014 CX-5 (seen 2 winters) -28K miles
 www.youtube.com
					www.youtube.com
				Thanks for the tipUndercoats are not all equal. Rubberized undercoatings will do more harm than good because they will trap moisture against metal and actually cause more corrosion. You can see the results of this on Youtube videos:
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.www.youtube.com
You want an oil based film like Fluid Film or Blaster Surface Shield.
I'd pressure wash it first and apply rustproofing after it's dry. You're not going to cause any rust if it dries. Not having a pressure washer I used the self serve car wash high pressure spray. Naturally I couldn't get into all areas very good but it was OK. I did mine in the fall when the air was dry so as to not trap moisture.@Jmaz thanks for sharing. Do you think it's a good idea to run the pressure washer under the car first or let it be? On one hand, I'm thinking let's get everything clean before sealing it up. On the other hand, I'm thinking water + air + iron equals rust...
				 www.fluid-film.com
					www.fluid-film.com
				 www.cosmolinedirect.com
				So...cosmoline vs lanolin? One dries matte black, one stays wet. Will need to research further. Thanks.
RP-342 "BLACK" Military-Grade Rust Preventive Spray
Now Available in BLACK - Our Strongest, Longest-Lasting (and Fastest-Drying) Rust Preventive Aerosol, PERIOD! Offers the highest concentration of Industrial-Grade Cosmoline® available in a convenient Aerosol Can. 1-coat protects all metals, iron, steel (stored Indoors or Outdoors) for Years...www.cosmolinedirect.com
Do you know if CRC Marine Heavy Duty Corrosion Inhibitor rubber friendly? Did you protect the ball joint rubber boots and brake lines when you’re spraying it?Here's a couple of pics to show what the CRC looks like when applied. The first pic shows the amber color on the white plastic piece where too much was applied and it has a few runs.
The second pic shows a little better that the coating leaves a semi gloss sheen for instance on the lateral link behind the rotor. Also coated the brake line fittings and bracket. The pics give an idea of the thickness of the coating and the degree of it's transparency, so it's not like painting the parts. After seeing cosmoline coated parts in the military, I'd call this stuff "cosmoline lite".
Same here. I can see some surface rust under chassis on my 2016 CX-5 which is seldom seeing salt road in Dallas area, but my 26 year old 1998 Honda CR-V and 24 year old 2000 BMW 528i suffer very minimum or almost no surface rust under chassis. Some say surface rust is no big deal, but it eventually will develop into deep rust making it difficult to loose the nuts and bolts. This just shows Mazda has failed on rust proofing process under chassis comparing to other car manufactures on my book.⋯ I’ve seen some surface rust in some areas on my CX-5 I attribute to that. It’s either that or the steel used as my G35x which sees mountain pass use as well doesn’t exhibit the same.
As far as I know--- yes. It's one thing I looked at before choosing. Here's the manufacturers website. It lists what it can be applied to and check out the video there. In the video you can see the color on a white background when it's applied to electrical terminal strip. There's also youtube videos of different products being tested. It's on some of those too. I sprayed directly on the boots, no masking, but I didn't soak them either, just a light coat. I did spray heavier on on metal parts and fasteners that do corrode.Do you know if CRC Marine Heavy Duty Corrosion Inhibitor rubber friendly? Did you protect the ball joint rubber boots and brake lines when you’re spraying it?
				 www.crcindustries.com
