The sound might be coming from the cooling fan, which is a part of the bi-LED solenoid, integrated into the harness.  This is how the fan looks like.
If its confirmed that its the fan, then the bearings might require some oiling.  Nevertheless, I would suggest you to insist on the dealer to replace the entire unit, since you are in warranty.  Mazda's signature lighting has a horrible configuration for its DRL.  It always keeps the headlights on, no matter the conditions of the day. This will reduce the lifespan of the headlights and will cost a fortune to replace them once the lights are out (estimated price for both headlight unit replacement is $3000 to $4000)
I simply pulled out the DRL fuse from my vehicle and I turn on the parking lights in case I need DRL during gloomy weather conditions.
