- 2014 CX-5 Touring
Actually I just bought all Japanese made PE01-14-302A oil filters in their stock on the other day and Med Center Mazda now has no more Japanese made OEM oil filters.![]()
Well poo on you
Ha, I thought I was the only one insisting a Honda filter which is made in USA by Filtech instead of the one made in Canada by Fram! Now our 1998 Honda CR-V has 175,233 miles I have eased up my persistence and used a free Fram Extra Guard oil filter came with 5 quarts of Castrol GTX oil purchase for its recent oil change.Yeah they're Taiwan-made filters. Of course the one I removed was a Japan-made filter. Does it really matter? I remember years ago I would go to the local Honda dealer to pick up a Honda filter, and I would always tell them I wanted a "Made in USA" filter by Filtech, as opposed to the Made in Canada filters for Honda, made by Fram. Blech.
Maybe it's the Taiwanese filters that have this lube stuff on the seal already?
PE01-14-302A Japanese oil filter is going to be hard to find in the US. Yeah Amazon still has it but for $10.33 each! eBay's mostly is from Med Center Mazda and they no longer have it. The thing is Mazda North American Operations has decided to import (older and cheaper IMO) 1WPE-14-302 Thai oil filter and the old stock eventually will be depleted and gone!The Japanese filter is easily sourced from Ebay or Amazon if not locally. The ideal alternate filter specifically for Skyactiv engines should be (WITHOUT) Anti-Drainback Valve just like OEM specs<<< that's the most important part. I was at the store the other day and saw a premium Bosch Filter which does fit like a lot of them out there but it has an Anti-Drainback Valve. Would not meet specs. The Wix 57002 on the other hand doesn't have an Anti-Drainback Valve and would meet specs.
What's wrong with having an anti-drainback valve? Is it because the filter points down on this car and doesn't need one?
Oil filters that are mounted with the threads pointing up, they don't really need an anti-drainback valve cause of gravity naturally keeps the filter filled with oil. For oil filters mounted with the threads pointed down or sideways, oil can drain out of it, so an ADBV helps to keep the oil filters primed with oil so that on start-up, it doesnt run dry. Thats why I fill my oil filters before installing them.
I don't think it would hurt to use a filter with an ADBV.
Heh, I am working in AZ atm. Can you suggest a good AZ dealer near Phoenix?
Avondale Mazda has a good service department. Their sales department is a bit aggressive.
