I've had my MS3 for a week now and am underwhelmed with the Bose. I want to retain the head unit as I like the Bluetooth 2.0, Nav and Sat integration. My problem is I'm getting mixed answers from some of the installers.
One installer says I can remove the Bose amp and speakers and sub and that the signal from the head unit will be useable, as it is, straight into the new amps.
The second installer says the signal from the head unit can't be used. The bose amp must remain and a controller added inbetween the Bose amp and the new amps. He says the controller is necessary to bring the signal back to full range as the signal going into to the Bose amp is cut off at around 2000hz.
I don't completely understand. It seems to me that using the high level signal after the Bose amp would distort the signal going into the new amps, but if its not full range until then I guess its necessary.
Can anyone clarify?
Can anyone clarify?
