Hello,
I have auto trans MP5 2003 with 97k. Its slipping between 2nd and 3rd gear. She will try to shift and 2000 rpm at a normal driving speed and will slip to about 2700-3000 rpms and catch 3rd gear and drop to 1200-1500 rpms. I don't have a slipping problem in any other gears. I have been driving with the sport shift and letting off the gas between 2nd/3rd as if i was driving a stick to help with any further damage. If I keep the pedal at 1/3 acceleration(normal driving speed) the trans will slip with the same symptoms as in Drive. I put a quart of Lucas oil stop slip and seemed to help slightly. If I am driving very light on the gas it wont slip too hard as before with out Stop Slip it would. In the morning it doesn't slip at all (probably due to the viscosity of the trans oil being thick when cold) at operation temp is when I have symptoms. I live in Hawaii so it is always hot here 70-80 degrees.
Plugged in the OBDII reader and it spit out these codes:
p0118 (Coolant temp. sensor below regulating temperature)
p0128 (Engine coolant temp. circuit high input)
p0126 (Insufficient coolant temp for stable operation)
p0325 (Knock sensor one circuit malfunction)
p0660 (Intake manifold control solenoid)
I knew about the coolant sensor for a while now but haven't replaced it. I am worried because I do not see a code involving the trans.
A friend of mine mentioned that sometimes trans have a feature that may run off of the vacuum lines and if something is wrong with the vacuum then the trans will have symptoms. (not sure about this??????)
I am not sure what to do at this point... Other than replace the coolant temp sens. and the knock sens. But, I don't think that will fix the trans issue.
I am wondering if this could be symptoms of the transmission solenoid? As I understand there are a couple that assist certain gears??
I really need some advice. I am a college student that is not rich like the top one percent of our country. I have been working on cars, trucks and dirtbike since I was a kid and I need to know what exactly needs to be done so I don't waste my time and money with trial and error. If my trans goes it will total the car and I c wont be able to afford a new one.
Please if you have any thoughts or similar ideas please let me know.
Mahalo,
Derek
Mahalo,
Derek
