I'm parting out my car since I wasn't able to sell it complete, so start asking about parts! PM or reply. I can send you pictures of parts if you want.
See the bottom of the first post for a complete list of items sold. Updated regularly.
I've finally replaced my Protege5 as the rust monster is getting the best of it...including some of the frame!
So now I'm selling the car. I'm located in Kitchener, Ontario, Canada.
First, details on the car:
- 280000kms
- silver
- 5 speed manual
- sunroof
- exterior has rust (mainly rear wheel wells, frame around windshield, and a good size hole in the frame (~4" diameter); some smaller areas on front edge of hood, front lower corner of drivers side door, rear hatch around emblem/license plate, and other spots around the car)
- interior is used, but in very good condition (I ought to have given it a good vacuum before I took the pictures). I have the cloth floor mats SOLD.
- features of the car that I know aren't working: driver's side rear door power door lock, front and rear washer fluid pumps, fog light bulbs burnt out
- factory stereo with AuxMod for auxiliary input (http://www.sylfex.com/products/AuxMod/) SOLD
- repainted interior accent pieces to a darker charcoal grey
- leather shifter boot SOLD
- engine/transmission are running well, though they obviously have 280000kms on them as well. Haven't noticed any slipping of the clutch yet, and possibly a slight noise beginning with 2nd.
- new brakes in rear within last 2 months, and serviced front brakes
- decent tread remaining on tires
- have winter rims with tires, but tires are low on tread SOLD
- just re-tinted all windows except the small rear windows @ 35% (the fixed ones, not the little triangles in the doors)
- home-made roof rack, which I can leave on, or remove and reinstall the trim pieces at your preference.
Selling anything that is reasonable to ship and not a huge job to remove.
Reply to the post, or send me a PM if you're interested.
Pictures below:
SOLD:
- AuxMod chip for stereo
- Airbag skin and cruise control switches from steering wheel
- MAF sensor and pipe
- all wiper arms + rear wiper motor ass'y
- floor mats
- shift knob/boot
- rear seat split hinge
- front/rear bumper skins and side skirts
- driver side rear triangle glass
- cruise control bracket
- battery tray
- ECU + harness
- tail light wiring harness set
- power mirror harnesses
- roof rack deletes
- rear cargo area cover
- power steering pressure hose
- axle-back muffler
- left taillight housing
- remaining 3 functioning power lock actuators
- air box
- intake manifold/throttle body/EGR valve
- instrument cluster surround
- fuel line from right side of fuel rail
- rear view mirror
- coolant reservoir
- alternator + bracket, bolts, and belt
- crankshaft, one piston/rod, strut bar and brackets
- centre console
- cupholder, radio bezel, power window control bezels, interior door handles
- ashtray
- Driver/passenger side mirrors
- All brake calipers
- cam position sensor
- clock spring
- pre-cat
- fuel pump
- rear sway bar brackets/bushings
- trailing link bolts
- side mirror sail trim pieces (both)
- front R and L strut assemblies
- windshield washer fluid reservoir
- antenna and associated wiring
- HVAC controls from below stereo
- both driver's side door sills
- driver's side B-pillar lower panel
- front passenger seatbelt with retractor
- 280000kms
- silver
- 5 speed manual
- sunroof
Pictures below:
SOLD:
- floor mats
- shift knob/boot
- battery tray
- ECU + harness
- roof rack deletes
- axle-back muffler
- air box
- rear view mirror
- coolant reservoir
- centre console
- ashtray
- clock spring
- pre-cat
- fuel pump
