20 HP Gain without any tools required!!!
nonopr
Contributor
2007 MS3 True Red
According to Sport Compact Car this month you can gain 20 hp by just opening the top of your air filter housing in your Mazdaspeed 3. Dyno proven an all.(hump)
There you go cheaper horsepower than that nothing.
Meaning that your not using your filter anymore? Im sure that cant be good.
Yeah, but the air is just gonna pass over the top of the filter and not pass though it right?
The air is pull thru the filter from the bottom. Still 20HP free.
So you just get rid of everything below the air filter? If it works I guess its cheaper than anything else u can do lol. Free mods FTW!
Ok so the air coming thru the bottom is going thru the filter but the air going thru the top is just going into the intake not filtered, for some reason I can just feel the grime building up in the head, the rings yelling for help, and the cylinder walls getting scared. No thanks I'll by a real intake and get my HP that way. I heard that to, but thats on a dyno in a closed area, not driving on the street everyday.
Dude what part is not to understand. Just take the top of the filter box(the Cover) that is it.(rockon)
that is not a smart idea, the reason its getting more hp is because the damn air isn't coming in thru the bottom it's getting sucked in more directly through the top where it will bypass the filter and screw up your motor. They used that as an example on how intakes effect cars, they were not recommending you do it as a mod on your car that you drive on the street with real time conditions.
Complicated people..
What ever. You guys are looking for minor detail. I just read that you just have to open the filter box and that is it. All the air going to your engine is filter by the air filter.
Get it.....(lurk)
Yeah, I understand. But if air flows from the bottom to the top and you open up the top then all the air will miss the filter? But hey, I dont have a MS3, the only time ive seen the air box on one of those things was when I was installing the first ever CAI on a MS3, so I may be wrong. You should get a CAI, its a b**** to install lol.
Hey then do not comment on this matter. Sorry to be rude . But is OK.
Get it.....(lurk)
dude have you looked at your intake, if you take off the top the filter is in the lower section, all thats left is the open tube, with NO filter, that is just dumb, dumb, dumb, please people do not do this.
Once again, this was in a control area and in a dyno. For sure I am not doing this with my Baby...................
Thats what I said, but im gonna excuse myself now....
And please, this guy just posted this, and thats it. He just read it somewhere and posted it, nothing more, no need to b**** at him.:)
i took everything out from the front of the hood to the entering of the filter box...it runs better,but it is also louder....however,since it is a 1.6..it is not 20 hp!!
