2.3 cyl engine question cx7 & ms 6
Int3grity said:
I was just inquiring because hell they have the ms6 doing 375whp look at the forums guy is running 21psi :-) and we have same engine so you know im curious
Do you have a link for the guy running 375whp? I haven't seen that yet. Stock, the car only puts down 210-225 so that's another 150whp.
I still think that the transmission is going to be this car's weakest link. Most of the engine internals are already forged, suspension is pretty stiff and should handle some added stress (though lower would be even better), brakes are respectable and should be able to handle a good amount of stress.
However, if I were tuning a stick shift and added 100 hp to my ride, an upgraded clutch would be a necessity. Automatic, that's not even an option.
I would love to be wrong though, so someone please show me otherwise!(drive2)
At the racetrack (raceway park) englishtown nj we have seen several automatic mustangs racing. These cars where modded but had auto trans.
next time I go I will make sure I take pictures of them.
I switched my 64 GTO drag car (Super Street Eliminator Car) from the stick 4 speed muncie to a turbo 400 because of repeated broken differentials and drive shafts twisted into a pretzel.
But I added a 4,000 rpm high stall torque converter, stiffer than stock 1st and 2nd gears and a trans break that allowed me to rev the motor to 4,000 rpm while holding the button and when we saw the yellow I would floor it and release the button and all I would see is blue sky for the next 60 ft. It also had a full manual valve body meaning you had to manually shift it (stronger and quicker harder shifting) with a reverse valve body which means you did not push the shifter toward neutral/reverse. You pulled it back like the CX7 away from these.
It stopped the breakage. But newer trannys are not a buff or as simple as the good old Turbo 400. While great for drag racing, they are a drag when doing the twisties I still prefer a Manual so long as I am not busting stuff.
It would be interesting to see if someone would make a higher stall torque converter and a shift kit for our tranny to make the manual shift quicker and firmer. This may take the form of a program for the TCU vs a physical valve screen changes.
Spoolinup said:
Oh, and hotrodding the CX7 would be a blast, in my opinion. How fun would it be to pull up to a light in a 4000lb grocery getter and put a beating on a newer GTO, or possibly a later model non-z06 vette? Haha, I would personally love it!(2thumbs)
I used to love doing that in my 2001 Dodge Ram 2500 (Cummins). Weighed 7000lbs but ran low 13's and 1.8x 60ft times (ughdance)
The look you get afterward is worth a million bucks..
I used to do that with my VW Bug 1.9 liter weber stroker motor, and a pain in the ass to drive but it ran 13's and seeing a Nova driver 5.7 liter engine get out and kick the side of his car in at Infineon raceway... Priceless....
I don't think my CX will do that yet... More money and time needed...
Whoot whoot englishtown! I'm going back up to Jersey this week. Will be staying in good old Manalapan with the mother-in-law. Unfortunately, I will be CX-7-less, but I will have a rental to abuse!
-back on topic-
Don't go out of your way with the photos. Once I get home I will look for the article I read putting the hp limit on our trans roughly 300 hp...(gossip)
It's the same transmission as the Volvo XC-90. It's rated for plenty more then 300hp. As I stated before, someone found the specs on the transmission manufacturer's site that stated 400 or 450ft-lbs of torque as the limit. I checked myself since I didn't believe it and came up with the same figures based on our tranny part number. Do a search and you should find the post about it.
Here is the discussion we had previously.
http://www.mazdas247.com/forum/showthread.php?t=123640300&page=3&highlight=CX-7+tranny
Sorry, been away for vacation and just got back. I haven't been able to find the source for the article I referred to, which leads me to believe that I was probably confusing a forum post for actual data. Having the transmission part number was very helpful; I really appreciate the information! It is good to be wrong!!!(cheers2)
The transmission may be the weakest link next to the limit our turbo can produce on our vehicles, but we do have options available for automatics as in valve body work and "bulletproofing" transmission. I can only remember one of the shops used from when I was in the Nissan community, but they used to do great work for automatic transmissions as I am sure they still do: http://www.levelten.com/ I would give them a call see if they can do anything for you. If I can remember the other shop that deals heavy into automatics I will post it..
In reality, it's better to have an auto with a turbo motor anyways. No power loss between shifts, since there's virtually a constant load on the motor. Every time the load is lessened on a motor, a turbo will not spool as quickly, and where as larger displacement motors can make up for the loss of power between shifts, it's not so easy with a manual transmission.
Manual transmissions are funner tho...:D
frasdl said:
You can always add a bigger turbo. The better question would be would you really want to?
There are all sort of things that occur when you go that route. More heat = need for more cooling. More torque/hp = tranny strain. More speed = need for better suspension and better brakes. You'll need a professional tune, etc, etc. Most likely it will shorten your motor/vehicle life and kill the value of the car due to marketability.
Seriously though and this is just my opinion, but I'm having a hard time seeing this a a vehicle to go mod crazy on. I know the potential is there with any turbo vehicle and maybe folks are encouraged by Mazda's links to modded out cx7's on the factory site. But I have to be honest, if I were to see a cx with a fart can and a BOV I'd be 1st in line to laugh at you. It's not like you can autox or do a track day with the cx7. I guess you could, but why. If you wanted a sports car, why get this vehicle? It's not like the market is limited with choices. And I'm guessing you don't want the bigger turbo to have more towing power.
Just my 2 cents.
Why is there a Cayenne turbo? 500 HP and stupid fast SUV. Because some like it, not for the auto-x, but some other desire.
It is a luxury and hobby for most people that mod. Knocking it because it seems ridiculous is ridiculous! Not everyone can afford the Cayenne, but a 500 HP CX-7 would be just as cool for some.
