2.0t03speed
- 08.5 CWP Speed 3
Hi guys i just want to make this thread to show my progress with my newly acquired gen juan CWP MS3. The car has 110k on the chassis and 4k on the pu motor (feb 2013)
Current Mods
Engine:
PG Turbo Kit with Borgwarner S360
HTP 4" Intake
HTP 51R Battery Tray
CFM Oil Cap Breather
SSP Primary EGR Delete
SSP Secondary EGR Delete
Corksport Oil Catch Can
Fumoto Oil drain Valve
SURE 1/8" IM Tig
SURE 1/8" TB Tig
NGK 1 Step Colder Plugs (.25 Gap)
HKS CBE
PG Under Motor Piping kit w/ Treadstone TR8
GFB Respons 50/50 BOV
Tokay V1 Injector Seals (Waiting to Install)
KMD Fuel Pump Internals
4-Port EBCS
Cobb V3 Accessport (Self tune)
SP63 Ported Intake Mani
3 Bar Map Sensor w/ SP63 pigtail
Aquamist HFS-3 Meth Kit (Dual 1.2mm Nozzles)
Howerton Engineering Dual 2 Gallon Tank/Pump enclosure
Drivetrain:
Act clutch
Act Flywheel
CP-E Stage II Rear Motor Mount
Corksport Passenger Side Mount
Corksport Transmission Mount Insert
Interior:
Ralco Short Throw Shifter
Corksport Shifter Base Bushings
Exterior:
DDM Tuning 5k low beams
DDM Tuning 5k Fog Lights
Cp-e Towplate
Ray's Engineering Gramlight's 57F 18x8.5 +37 in front +40 in the rear
8mm Spacers in front
5mm Spacers in rear
Ray's Engineering Black Lug Nuts
Dunlop Direzza ZII's 245/40 R18
Suspension:
Fortune Auto Coilovers
Moog shorter front endlinks
Dominant Engineering Rear Camber Arms
Corksport Rear Sway Bar
GT Spec Rear Tie Bar
EBC Yellow Pads
Centric High Carbon Rotors
Goodridge Speed Bleeders
Goodridge Stainless Steel Braided Brake lines
Most recent photos:
Current Mods
Engine:
HTP 4" Intake
SURE 1/8" IM Tig
SURE 1/8" TB Tig
HKS CBE
4-Port EBCS
Drivetrain:
Act clutch
Act Flywheel
Interior:
Exterior:
Cp-e Towplate
5mm Spacers in rear
Suspension:
EBC Yellow Pads
Most recent photos:
