when I switched from 17s with 40 series tires to 17s with 45 series tires, it made a big difference... ride is very good nowJeph said:I am on my 16 winter rims, and i like the ride quality of my 16s better then the 17s with a 40 series tire. No way should you get 18s if you want to keep a nice ride quality
nate0123 said:(mswerd)
at least on a protege
any size that requires a 35 series tire is impractical IMO
it all depends on the offseti12drivemyMP5 said:I have 17x7s with 205/40s. Car is lowered 1.3. Ride is not crazy rough but noticeably different than when the 215/45s were on it & not lowered. 205/40s make speedo say 60 but really doing 59.4. 215/40s will make it say 60 but really 60.2. Want to go to 215/40s but not sure if it will rub when car is loaded. Right now 3 bikes, 3 adults & gear don't make it rub or bottom out badly at all. Afraid 215/40s will have issues. Anybody with 215/40s & lowered 1.5 all around? Any issues? Can't speak to factory sizes, car had 17s already on it brand new from dealer with 56 miles on odometer. I don't even have the 16s...............
PhiTauKid said:What Can I do I have a 2002 protege 5 with the 16X6 that take 195/50/16 the problem is no one in cinncinati Has any, I can get Kumho's but the snow is coming and the directional pattern failed the snow test last year, so I'm trying to find Mazda 3 rims, or 6 rims I think they are 17X8 What other Mazda rims can I buy?????
pktjed@yahoo.com
good point, yea... just get some toyo proxes4 in 205/50-16tunersteve said:205/50/16 is a much more common size, and will fit just fine on your stock wheels. Ask for those next time and you should find a variety of sets. When my Dunlops wore out, I ended up with a set of Toyos in that size.
nate0123 said:it all depends on the offset
215 width will fit just fine if the wheel is the right offset
