17x8.75 wheels on a p5
Mazda SP20 2001
What will I need to do to fit a 17x8.75 rim on a p5 and is it possible and wat size tyre would go with it . No scrape wanted and lowered 2 inches . Thanks ppl
possible yes. i even did 17x9.5 in the rear. the 17x8.5 in the front fit nicely
the rear had some poke to it
i ran them with 205/40/17 tires
you will have to massage your fenders. depending on the wheel offset, you may need to run spacers, too.
Well really almost any wheel width within reason can be achieved but like stated above it's all about offset and even camber after offset has reached it's limit. Like I have stated before to some, look in the Stanced and Slammed Life Thread. That will give you ideas what you can run.
