would 17x7.5 pose any problems with a 40 offset?
Anyone have an answer to this one? I'm looking at some rims with this offset, but haven't found a straight answer to it...
BTW, my suspension is stock, so no drop to worry about.
Daniel
Should fit fine with a stock width tire on there and no drop (stock MS3 is 7.5 on 52mm offset). If you want a wider tire, you'd need a higher offset or some rolled fenders most likely.
I've been reading through some wheels threads trying to decide what I should do about winter, and god damn it's hard to figure out what my best bet will be -_-
Slow corners were ok, but with speed in the corner, it felt like the back of the car was going to kick out, it was "floaty". If you aren't all about cornering, then go for it. The acceleration was definitely better, and the MPG increase HAD to be better, I didn't go through a tank, but I'm sure it would have made a difference. I just like to hit the corners a little hard once in a while and I didn't feel safe whatsoever. Lesson learned for me.
Same. I went to tire rack and they have a set of 16" steel wheels that will fit, and they have an insane price on 16" closeout blizzaks right now. I was thinking about buying my winter tires early this year...
Do it! I got that same package with the 215/55/16's and it was right around $500 to my door... you won't find a better deal
16innch steels will clear stock caliper on ms3 both front and back???
