1/4 mile times people are getting in there MS6
SOSPEED
2010 ms3
So what are peolpe getting for 1/4 mile times in there MS6.. I am tring to decide if i should get the MS3 or MS6...
Not as fast as a legacy GT. If you want to go fast in the 1/4 you shouldn't buy a mazda.
Also, THEY'RE at the track running THIER mazda in that lane over THERE.
But if you act quickly you can run the 1320 a little slower for alot less cash :)
you can run high 13's if you don't mind going though trannys. I suggest you get a old camaro if thats all you care about.
Yeah thats my thought too, AWD cars aren ot really intended for the 1320 honestly, there is no advantage to be had....
Jackelope said:
u basing the decision just on 1/4?
No but its one of them and i have looked in many mags and forums and have seen anything from 14.9 to 13.7 in a stock MS6. So whats wrong with asking what have people been running. Also most mags are saying the MS3 should run the 1/4 mile in about 13.9 so if a stock MS6 can do it in 14 flat or 14.1 than maybe the MS3 will be a little faster than what they are saying. I know i will be buying a car in the next year or so and i have narrowed it down to the MS6 or the MS3 so yes speed would be a factor in the buying process.
dread said:
13.7 sec was the best that I have heard of.
A lot of small talk for a simple question...Thanks dread for getting to the point!
I think the main difference between the MS3 and MS6 at the track would be traction...The MS6 seems like it would be easier to get consistent times while the MS3 will take more skill (and slicks?) to get and stay in the 13's...BUT...the MS3 will kick serious ass once you dial it in...
Nothing wrong with asking this question. Flipandfunk doesn't own a MS6 and just goes around making these types of comments all over the board. There are several people on the boards running 13.7-14.0. The MS6 will obviuosly have a traction advantage, but the MS3 will probably catch it by the end of the track. Running about the same time, but at a higher MPH. The MS6 will be easier to run consistent times in, but the MS3 will be a serious freeway screamer. Third and fourth gear will be a riot in the 3.
Hope this helps.
Hope this helps.
Thanks for the input.. But one ? Why are motortrend, car and driver and road and track saying 14.7, 14.8 or 14.9. Those are the type of peolpe that know how to drive a car and should be putting down the good numbers. The last time i check in the back pages of car and drive in there list on specs on cars it says Mazdaspeed 6 1/4 mile 14.9. I would if it was a type-o and they meant 13.9???
Yes, he does. And his point is valid. The MS6 is prone to issues with the rear diff and hard launches. The bushings fail and then you're at the dealership. There's a backorder on them so be careful. He's abrasive, but his data is typically correct.
I was talking with a guy who owns a MS6, he did say he was short shifting, but he got a little over 16 I believe. 14.9 ish is probably more based in reality.
(peep)
while i agree that awd isn't meant for the quarter mile, i'd rather drive an awd down the quarter than a fwd car (especially on street tires), but a rwd car would be the best. when you see shep or any of the big awd guys launch, it's a thing of beauty :)
My point is just that s 300 HP sti Vs a 300 HP MGT is a bad race stock, take the difference in funds though and put on cheater slicks or even full wrinkle walls and the AWD advantage is out the door and now becomes a DISadvantage because you gotta lug and drive the extra axles and what not alllll the way down the track!
I will also say this: My last car was a Ford Probe GT than ran consitent 15.2's @ 92 and my MS6 is at least a half second quicker on feel alone, I would bet my title on that! So the 14.9's are enigma's or on bad days (cold track or something). Also car magazines such as road and track, motor trend, automobile.... while "good" drivers, they try to net numbers that an AVERAGE driver could replicate, thus they will not test the limits of the clutch or drivetrain as much as you or I will, and i bet my grand mother could pull a 14.9 EASILY. Do I think the MS6 in MY hands can go quicker... you bet!
The MS3 will be quicker in 1/4 mile and on the freeway or making a pass. Third gear is crazy on that car from all the reviews/forums I've read. It is a few hundred pounds lighter than the MS6.
13.8's and 13.9's (on a gtech) without launching it too hard.:) and the car could go faster in the hands of a better driver.:)
