03.5 Blazin yellow MSP partout
Status
Not open for further replies.
HI, I need passenger side front and rear ABS sensors. Looks like the front passenger one is sold. How much you want for rear one shipped to 98092?
Thanks
Hey man I APPRECIATE you actually looking through the parts sold list before posting! The rear pass side is the one that took the damage but the abs sensor might be ok. I'll have to check and get back to you.
not sure if it sold but the full turbo setup including oilpan and smic
it's sold
Im looking for the coolant reservoir cap
it's sold
Thanks for getting back. Please let me know if you have it and how much, need to get it asap cause I need to sell my MSP
Updated list of parts that have been SOLD:
Side markers, shift knob, washer kit, lower grill, door sills, headlight supports, ecu cover, DF inner wheel plastic cover, egr tube, cup holder(shifter bezel), inside DR door handle, shift boot, Ebrake boot, TURBO KIT(rad+intercooler, rad brackets, turbo, wga, oil+coolent lines+ oil cooler, exhaust mani+shield, S+J pipe, hot+cold pipes, air box, MAF, BPV+hose, MSP ecu, ac condensor), PR door complete, rear strut hats, front A pillars, Engine, headlights, RB springs, climate controls, insturment cluster, wheel center caps, coolant reservior, engine harness, glove box cover, fog deletes, msp engine cover, R skirt, hood latch, msp pedals, dual cat, both O2 sensors, dash bezel, rear cross member, bumper cover, pass axle assm, bump stops, spare tire and cover, dipstick, DS jam sill, coilpacks+plug wires, DS rear caliper, DS front caliper, TRANNY, DS door, DS fender, 03.5 LIP, PS rear view mirror, radio bezel, grill, pr seat belt assm, horn, sub brackets, Pass ABS sensor, Driver's side hub and axle, pass window switch bezel, brake booster line, sub encloser kit, fuel pump, fuel pump assembly, dimmer switch, seat covers set, radio pocket, ac compressor, rear MM, shifter, shifter plate, shifter link arms, master cylinder, clutch master cylinder, slave cylinder, clutch line, throttle cable, gas-brake-clutch pedals, pressure plate-clutch disc, flywheel, starter
i would like the a-pillars if they are still stock. also, could use a rear pass. side floormat (spilled acid on mine ) and the kickpanels
front bumper available? i read the sold list and didnt see it there
dont need the front lip.. just regular bumper
Im interested in the rear wing if it's in good shape and still up for grabs. Didn't see it in the list.
^Rear 1 is trashed. Front 1 still in good shape. Was asking $100 shipped for the front swaybar, bushings and brackets.
Status
