- 2018 CX-5 Sport
I aired up my tires today and the rim coating on one tire pealed away in two places. I am unaware of hitting the rim on anything. Has this happened to anyone else? Is there an adhesive that I can use to glue it back on?
I had read here that dealers often forget to deflate the tires to 35 psi after they arrive over-inflated for shipping. I thought the ride was a little harsh (I've only done 50 miles or so), and then I remembered to check the tire pressures. That's also when I was surprised to find I couldn't check pressures with the TPMS.I'm disappointed that the dealership (you know, the "professionals" that know the car better than anyone ;-) ) gave it to you with the tires overfilled by about 25%. Then how do they expect you to trust or believe any work they do going forward? Shame businesses work like this. SMH!
I have a 2020 CX-5 Signature and the MyMazda app on my iPhone; I can't find anywhere where the app even mentions tires, much less gives pressure. Where in your app do you find this info?I am using the MyMazda app, and for some reason the 2020's will show tire pressures on the app, but not 2021.
Select Status. About halfway down the screen it says "Vehicle Status" with an arrow pointing up. Press the arrow and the screen expands upwards. Now you can see an image of the car, and there should be a tire pressure displayed for each corner. You may need to drag the top of the screen down to refresh.
