2017 CX-5 Sport Suspension Noises
Hi, all. I recently purchased a 2017 CPO CX-5 Sport with 31,000 miles on it, almost 3 weeks ago. I am enjoying the vehicle quite a bit but have two concerns. 5 days into owning the vehicle I noticed a creaking noise coming from the front-end suspension when turning my wheels, such as when going from drive into reverse. Didn't think much of it, but now I can hear some creaking/crunching (like floorboards) even when driving slowly over various undulations in the road. Today backing up into my driveway I heard the sound quite a bit as well.
I know the quick response will be, "take it to the dealer". But, given that the weather has turned cold it's when I really started noticing it, and I know that vehicle components tend to get a little noisier when it's cold out. We didn't hear it on the test drive, and it was almost 70*F that day. My 2015 Hyundai Elantra has some noisy bushings that have been just fine for over 40,000 miles, and the mechanic said they're fine. I'm wondering if it's the same situation here. Either way I'm going to bring it up at my first service visit in March, but it's a little upsetting to hear this right away, and with my luck they'll say everything checks out. My question, has anyone had similar issues? I've searched the forums and it seems limited.
Additionally, I get a clunk/rattle like noise from the right rear when I turn onto streets or driveways. It's intermittent, though.
Thanks!
2019 CX-5 GTR
you are gonna want to use that fancy SEARCH option.
start here:
and go from there.
TLDR; if you can get video with clear audio and post that then diagnostics is gonna be easier. There is no single fix for "creaking noise coming from the front-end suspension when turning my wheels" or "clunk/rattle like noise from the right rear when I turn onto streets or driveways"
start here:
and go from there.
Lol, thanks. I appreciate that. I swear I searched high and low. These aren't quite the same noises I'm describing from the front end.
yrwei52
Contributor
Plano, Texas, USA
Thanks!
There’re multiple issues which may cause front suspension noises on gen-2 CX-5. Check out this thread and the TSB 02-002/18:
Click/ Clunk/ Knock sounds 2018 CX 5 AWD
Alright, I got the creaking noise on video. You can hear it right at the 9-10 second mark; it's that initial creaking/crunching noise. The video amplifies the noise a bit -- it's much more subtle in the cabin. Apologies, you can also hear my arm moving/body shifting and it interferes a bit but you can still hear it. This was when I was reversing into my driveway with the wheel mostly turned all the way to the right (I try to avoid doing this but it's a wicked tight turn into my parking spot).
I'm determining whether or not to wait until my first service in March. I don't drive that much as I'm working from home (I've only put like 400 miles on it in almost 3 weeks). However, I'm going on a 275 mile round trip this weekend in the vehicle. My gut tells me this isn't an urgent issue, but would love input. Thanks, everyone, and Happy Thanksgiving!
So, since I noticed this creaking I've become much more hyper aware of all things suspension related. At night, I began to notice my headlights oscillating a little bit (like 2-3 times and relatively small) after I hit a series of bumps, which possibly indicates the front struts are rebounding more than they should. It's also very possible that this is due to a sort of rythmic series of bumps, as the roads around here are horrible...they dip, they dive, they have ripples, they undulate, they're cracked. We also have a main road constructed with concrete slabs that have joints every 50 feet or so. I have a new set of Altimax RT-43's and they're relatively mushy tires, so not sure if that makes a difference either.
This might sound a little odd to notice, but when a door is shut on the vehicle, it does a normal "rock", and then jiggles side to side 2-3 times (again, very slightly). On most vehicles I've noticed one hard rock from the door closing and then it settles. Is this normal? I did the "bounce test" on the front end and it oscillates maybe a fraction but not what I would call a bounce on rebound. Bounce test on the rear is rather easy...looks like one bounce (including roll forward and back onto the parking pawl), but again, just seems a little too easy to do.
In any event, I am going to have them inspect my entire suspension system when I bring it in for service in March. I've only put 1,200 miles on the vehicle since purchase, so hopefully all checks out.
Talking to myself here, probably, but hoping that if someone has any issues in the future they can read through this thread.
I actually recorded a number of bounce tests with my phone both on the rear and the front end, at every corner of the vehicle. I did one large bounce, and several series of bounces to get it oscillating. To my surprise, it is almost unnoticeable if it bounces at all. The shock and/or strut goes down once and then goes right up to resting height. Can’t see any oscillating. I’m a short guy, so it’s kind of difficult for me to get good arm leverage on the front end, so it’s anyone’s guess if I’m even doing it properly. But, when I’m driving and I come to a stop (gentle braking or harsh), the headlight line clearly oscillates up and down right when the vehicle stops. So something is indeed shaking; this vehicle doesn’t have adaptive headlights, only the manual positioning wheel so I’m not sure it’s that.
I will return with further updates once I finally get to the dealer in the spring. I still suspect a strut issue in the front.
AVC
'17 CX-5 Select
Use an open door as leverage to rock the car., or better... speed bump check where both wheels on an axle are working, is a bit more revealing. Rears checked same way. After the axle crosses the bump, one moderate dip, one moderate rise and then back level is good. If it falls deeply, rises steeply, falls again significantly, (more than one complete up/down oscillation) before settling, they are pretty cooked.
Also look if the struts are significantly oil stained; oil loss is a common failure.
Thanks for the reply. Speed bumps are actually fine, both rear and front end seem to settle just nicely and rather sturdy. The front struts don’t seem to be oil stained. Rears are definitely clean. Something may be going on with body roll, not necessarily front to rear or up down bouncing (as evidenced by the “jiggle” when closing the door, same as if I move abruptly in my seat or cars go by at speed when I am stopped).
I think I am probably overreacting, honestly. No use guessing until I take it to the dealer. The creaking noise I made this thread for is probably more annoying than anything (which, strangely doesn’t make a peep when I go over speed bumps).
Top
