N7turbo
2023 CX-5 2.5T ... 2024 MX-5 RF GT
Probably compared to gas without additives, which might not exist in the wild.Besides that, 10 times better protection than what?
From website bp says… "bp and Amoco gasolines with Invigorate® offers 10 times better protection against intake value deposits and helps clean any deposits left by minimum detergency fuels."
I think they meant to say "valve", not "value". Besides that, 10 times better protection than what?
The results showed that, on average, non-Top Tier gasoline left 19 times more carbon deposits on injectors and intake valves and in the combustion chamber than Top Tier gasoline had.
AAA also found that Top Tier gasoline can have a cleansing effect, reducing intake valve deposits by 45 to 72 percent when used over a 5,000-mile interval. Variation in the results is attributed to the detergents used by different brands.
I use it regularly, great stuff.Does anyone bother with the occasional bottle of Techron? Even though I only use Top Tier gasoline in my cars, I used to put in a bottle of Techron for the tank of gas before an oil change based on some random internet advice but I don't look at my valves to see the effects. I'm not going to bother with even more detergent (Techron) going forward unless another random internet advice compels me back.
Probably a couple times a year I add a bottle of Techron to the Chevron gasoline in the tank.Does anyone bother with the occasional bottle of Techron? Even though I only use Top Tier gasoline in my cars, I used to put in a bottle of Techron for the tank of gas before an oil change based on some random internet advice but I don't look at my valves to see the effects. I'm not going to bother with even more detergent (Techron) going forward unless another random internet advice compels me back.
Depends on which grade you use. The Mobil/Exxon and Shell premium fuels supposedly do a better job than their 87 fuels.Everyone talks about how great "top-tier" gasoline is, but when I use fuel system cleaner, I can objectively feel the difference.
So, I do suggest occaisonally using it, and it does imply the "top-tier" gasoline perhaps does not have sufficient detergents to keep the fuel system clean/lubricated on it's own.
I use only shell 91.
Sometimes yeah, following that same advice in the manner you described. Might only do it once every 10 or 20k miles though, and only if there’s a good sale on the detergent. No idea if it helps lol!Does anyone bother with the occasional bottle of Techron? Even though I only use Top Tier gasoline in my cars, I used to put in a bottle of Techron for the tank of gas before an oil change based on some random internet advice but I don't look at my valves to see the effects. I'm not going to bother with even more detergent (Techron) going forward unless another random internet advice compels me back.
I use it every oil changeDoes anyone bother with the occasional bottle of Techron? Even though I only use Top Tier gasoline in my cars, I used to put in a bottle of Techron for the tank of gas before an oil change based on some random internet advice but I don't look at my valves to see the effects. I'm not going to bother with even more detergent (Techron) going forward unless another random internet advice compels me back.
I started using that gas as well. Been very pleased. Maybe its butt dyno / placebo, but car feels way more responsive to accelerate than it did on regular.Been running Shell Nitro Premium in my 2025 CX5 Non Turbo. That, combined with bumping up to Pennzoil Ultra Platinum 5w30 (from 0w20) , couldn't be happier with the cars responsiveness, acceleration, and the way it purrs so quiet at idle I sometimes think the engine shut off.
It’s not something that’s going to grenade your engine, but over time it could get costly to fix. Direct injected engines are more prone to issues as a result of gunk building up on the injectors. It can screw with your fuel trim levels, throw a check engine light, cause rough idle, reduce gas mileage etc.been filling up at BJs for a long time. Can someone explain what mileage we are talking about here? 100k? 200k before problems starts? If I don't want to drive 200k I shouldn't probably worry about this?
