Gen 3 CX-5: Owners Chime In
I will test it on the move, but when parked in our garage, I did see them turn off when I did the simple procedure.
You'll definitely have to test it while moving, because that's when they automatically turn on and can't be turned off.
For the brake hold function, or simply releasing the parking brake without using the function? I definitely need to actuate the parking brake button to disengage it on my ‘23 without the brake hold function activated.
First time I read it above I took that as hitting the gas can disable the parking brake (sans brake hold function), but it could go either way. Would love some clarification. Great thread!
My experience with the parking brake not auto hold. My 2017 CX-5, after starting, would auto release the parking brake when the accelerator was depressed. I remember reading it in the 2017 manual thinking, great idea. I have not tested it on my 2025. I had a loaner CX-50 for a while and I really liked that when you turn off the car the parking brake automatically engaged. Wish the 2025 CX-5 did that.
Here is an image of the stalk. It might just be a way to run parking lights only? I didn't get out to see if the lower white beam (daylight running light) was still on after I saw the headlights turn off.
Yes, that bottom option is for the parking lights all the way around the car, minus the headlights. What I'd like to know is if Mazda has continued the mandatory headlight running once the car starts moving, even in that mode.
I will get back to you on that but I need to test this on a sunny day because the stalk pops back to AUTO after the headlight procedure is completed. What that means to me is that if it's dark out during the day (or night), like it was today, the headlight sensor will turn on the headlights regardless. Stay tuned...
My money says it hasn't changed from the Gen 2 unless the stalk (image from the Gen 3 that I shared here today) is different than it is on the Gen 2. I don't know our '24 Select well enough to say one way or the other. It's the wifey's car.
Yeah, there may be a difference between the trims once you are in premium headlight territory.
You'll be happy to know that at least on my '26 Preferred, the actual headlights are not part of the DLR system. See image. Two small projectors below the headlights are what run in the DLR mode. That lower setting on the stalk can actually dim them to a degree as well. But they are small and insignificant so I don't see why there is any need for that. In my supplied image, they are running at full brightness.
Gen 3 Mazda Genuine Accessory disappointment:
I ordered a Mazda brand retractable cargo cover online from Med Center Mazda store at a discounted price. The gap between the seat backs and the cover frame is large enough to let light in, even with the seats set in the reclined position. I'd rather not have a thief able to go window shopping into my new Mazda. :cautious:
Getting to know my new Gen 3...
There is one complaint that I have always had with modern automatic transmissions.... the shift programming...
Simply put, the trans upshifts depending on the pressure on the gas pedal, in an effort to improve fuel economy. The problem with that is that if you are traveling at a steady, slow speed and the trans decides to shift up to the next gear, the motor gets louder as it labors. Annoying to no end. While I didn't really care for the way a CVT creates a droning effect, I can say that since it works differently, the rpms were almost always perfect, basically eliminating any bog down.
Enter the manual shifter on the Mazda! Since our Gen 2 is the wifey's car, I rarely drive it so I don't have time to experiment with it. In situations like what I described above, simply moving the shifter to the manual mode will hold the ideal gear for as long as it is needed. That was quite refreshing.
I see. Then I presume that the feature is offered on higher trim levels of the Gen 2.
My 2016 was not really a high trim (Touring) , it was one above the base. I thought this feature was available across all trims.
Our Gen 2 2024 CX-5 Select will not release the parking brake automatically. It can only be released manually.
I have a 2020 one trim up from base and it will release the parking brake but I need to press the gas pedal quite a bit and it releases it with a loud bang, not too reassuring...I only tried a couple of times as I was afraid to break something!
Bingo! I thought my 23 Turbo didn’t do it for that reason. A little tap of the gas wasn’t enough, you have to push that pedal while expecting the parking brake to release.
Here is a new thread dedicated to the new generation CX-5. New owners, let's learn and share about the new generation together. Share experiences and tips. Ask questions, too.
I am just starting the process of getting to know my next generation 2026 CX-5 Preferred. I test drove one the other day and I was really impressed with the improved interior space and ride comfort compared to our 2024 CX-5, which we love. A lot has changed in functionality so it will take time to get to know it but it still feels like a Mazda, thankfully.
Points I've noticed so far-
The Gen 3 is taller by least a few inches than the Gen 2 so you have a sensation of being inside a larger car, yet it handles and maneuvers like the Gen 2, for the most part.
The Gen 2 is 66.3" high and the Gen 3 is 66.7". Front headroom is 39.3" in the Gen 2 and 39.2" in the Gen 3....
Could be a difference in the seat bottom height, or even the seat bottom itself. If the Gen3 seat compresses more than the Gen2 seat, that could account for the feeling of more headroom. Maybe the Gen3 has the driver's seat a little bit further away from the windshield, too?
Before you judge, I urge you to go sit in one. The front seats in the Gen 3 are a little bit lower, but still higher than a CRV, for example. I was thankful for this because the Captain's chair height of the Gen 2's driver seat made me feel like I was driving a minivan. But there is still a raised opening under both front seats for rear passengers to slide their feet well under them. Further more, the door entries into the front and rear seats have been raised so there is no more ducking your head to get in and out like there is in the Gen 2. There is a bulge in the roofline of the Gen 3 compared to the Gen 2, it's taller in the front end and in the roofline.
yes . Thats my impression too. Seat feels further from windshield and it is softer and wider. Front side space feels wider too because of the new layout and no buttons and diff arm rest. The overall feeling is like you are in diff car.
I am just quoting the specs of each car. There can't be that much difference. It's the same body as before, just stretched. You have a 24 Cx-5 correct? How about you measure from the top of your head to the roof in both cars. And from your hip to the door? According to everything I have read, the front passenger area didn't change. They added all the space to the rear seats and cargo area. The new one is very slightly wider and taller (~1/2") so it can't be significantly different. I am sure the layout makes it "seem" bigger but the passenger volume in front has to be almost identical. The total interior passenger volume is 104 cubic feet on a 25 and 106.5 cubic feet on a 26.
