Tires starting to crack
Steve didn't mention how much tread is remaining. If they're well above the tread bars id send em
Apparently the tread left is OK, not sure exactly how much remaining but the cracking and age was the reason they gave for replacing
Wouldn't worry about it if you mentioned saving money where possible.
I just got back from Discount Tire, the guy said there is still some tread life left and that they recommend changing tires after 6 years but that they don't look that bad and I have time.
I bought them 6 1/2 years ago so I am going to wait for a sale and research which tires would be best. I may just go for the ones I have now, the Continental Contact Tour A/S or something less expensive.
The guy at Discount recommended the Falken Pro G5 A/S for $119, the Continentals are $154. There is also the new Continental Tour 54 for $155.
He also said the Sentry Touring is OK but they are cheap which concerns me, around $65.
I would like a more comfortable ride and someone mentioned the GoodYear Assurance Maxilife but my car had a rough suspension when it was new and it's now 13 years old so tires can only do so much.
I will wait for a sale while I do the research.
I wouldn't buy those tires again if that is how they look like after 6 years.
did they sit out in the sun a lot?
The best place to research tires is Tire Rack. They have tests that show the best tires and also have millions of miles of customer reviews so that you can choose the tire that will best suit your needs.
Don't listen to our recommendations, see what the expert testing results are and compare the tires you might want to other based upon real world customer reviews.
I've been doing that as well. Even then it depends on the car as well. A 2013 Mazda 3 isn't going to have a smooth ride no matter what tire I put on, but I still like to read reviews
When you buy new tires, I would suggest covering them from the sun when parked outside for long periods, if possible.
That damage is likely to be caused by the sun. Especially with how high the pressures can get in there after sitting, (Considering that 36-37PSI is high for a light driving load) those two things together are contributing to premature tire cracking.
Honestly, I would not overthink tires. Don't buy the cheapest, and if you want to save money, don't buy the most expensive either. Just make sure you get your hands on something with a recent DOT date that's on sale and call it a day. You have time.
Can't cover the tires but it took over 6 years for the issue to show up which isn't bad.
I check my tires pressure often, keep it on the 36 recommended and I've never seen it go above that, they lose about 2 lbs over a few months
Car tires have a maximum pliability of 36 months. After that, the compound begins to slowly harden which will effect ride quality/handling. Add to that wear. Shallower tread is louder and has less cushion.
A prior vehicle I owned came with Hankook economy tires from the factory. They were garbage. Shallow tread depth and soft compound that wore out in 20K miles. I upgraded to Conty Cross Contact LX25 tires and never looked back. They had deeper tread, were more quiet, and most of all they provided a much improved ride quality all through their life, comparatively.
When these factory tires that came on my new Mazda wear down, I will be going with the aforementioned tires above.
I currently have Continentals, they ride better than the Michelins and Pirelli's I had before and don't tramline on the freeway like the others.
I have been waiting for a Coupon on Continentals, also considering Falken.
I am in the opposite position but the same predicament, 9-year old-car with 182K miles. It doesn't make sense for me to pay for premium tires either. I get nails at least twice a year and the car is AWD.
My favorite indie shop quoted me $600+ for a set of Armstrong 215/50R18 ($108/each). The thread wear warranty is 45K miles (a bit over two years for me). Mounting/balancing is $30/tire. Disposal is $5/tire. $600/24=$25. If the set lasts for two years, it'd be less than $1/day. 🤷
There is also Accelera from Amazon and Walmart that is around $80/tire, Bearway at Walmart and various online retailers. Are they good? Most Mazda owners wouldn't know. 😂
I only have 50,000 miles on my Mazda and financially I need to keep this car for a while so I don't want to go super cheap on the tires. The Falkens are around $119/tire not on sale, the Continentals though are $140 not on sale.
I got my Conti tires a few years ago during a buy-three-get-one-free deal.
There's always a sale going on by some big name brand. The trick is to find an inside sale also going on by the seller/installer big name companies. Combine the two for some good savings.
I signed up on the Continental website for offers
