EPB stuck
Hi all,
2016 CX5 owner with stuck EPB here that needs advise. My car wont move and pressing down the EPB switch does nothing . The parking brake light flashes red on the dash and I have a solid orange parking light present. The EPB switch itself also has a flashing light.
I did not do any brake work prior to this happening. Just tried to back out of my garage today and the car had the lights on the dash but it did not engage the parking brake. When I got back home from a quick trip the parking brake automatically engaged and when i switched off the car and it will not release.
I had a mechanic come over and take a look at it and his scan tool reports the EPB switch is faulty.
I was able to take the EPB switch out and examine it but could not see any issue.
Are these EPB switches (KA0G66EP0)
a known weak point?
Thanks for the replies.
I had seen that TSB before and knew about the EPB dragging issue. I am the second owner and I have not done this TSB fix.
In my case however pressing the EPB switch does nothing , no noise . The light on the switch flashes continously.
@nickswhip24 I cannot move the vehicle, I tried to reverse but the EPB just would not let go. The mechanic I called was for roadside assist . But he put a scanner on and said its the EPB switch and asked me if I dropped any liquids on it, which I did not.
Its night here in Australia now, tomorrow I will check the caliper numbers to see if its applicable.
@madar when you had the issue did pressing the EPB switch cause any sound from the actuator or did nothing happen as well?
Isn't there a release procedure (maybe in shop manual) where a person can crawl underneath and with a wrench/socket manually release the brakes.
No, I believe the issue was a worm gear inside the unit got hung up on some bad machining. Eventually it broke loose, but the car was only a year old at the time.
Ok well I found out how to release the EPB when the switch is not working. Apparently you have to wear your seat belt and accelerate forward or reverse. Ooops guess I tried without the seat belt earlier.
So at least now I have a working car, just a different way to engage or release the EPB for now.
@N7turbo out of habit . You are correct , its not necessary. Though I think even I do not apply the EPB, it is automatically applied by the car when the door is opened. This is what is happening now whilst the switch is inoperable. As soon as the car is turned off and driver's door is open , the EPB is applied automatically. To disengage , I need to wear the seat belt and put trans in drive or reverse and tap the accelerator pedal.
ok...good info,thanks
What trim do you have? I never heard of the CX5 doing that.
Right, it doesn't do that on the CX-5. What he's saying is that it is due to a malfunctioning switch. Hard to know what's going on for sure.
2016 CX5 2.5L NA.
Maybe this only happens when the switch is non functional. I dont recall this happening earlier but I always applied the EPB myself before opening the drivers door.
