I toggled display off with Mazda Connect, now what?
Punching myself in the face, I tapped on the "Display Toggle" script using MZD-CONNECT-1 to access terminal mode with v74. And now my display is black and I can't get it back. I've googled around quite a bit and can't figure out any way out of this. Does anyone have a solution? (or is it a trip to the dealer?)
Thanks in advance,
Paul
Solution
Good news, I simply purchased a used CMU on eBay for $86 and swapped my old unit out. It worked fine right of the bat. The only thing I had to do was delete all the previously saved favorites, BT connections, etc. Grateful it was only an $86 mistake. After I swapped the unit, I updated it to 74.00.324 and then ran MZ-CONNECT-1 tweaks again, this time NOT TAPPING DISPLAY TOGGLE!
Paul
Actually as it turns out I spoke too soon. Sure the display came back on when I re-installed the firmware. But afterwards, when the car was locked up and after 5 minutes, the screen is off. So I'm going to just buy a used KN3L-66-9C0 CMU and install it! If that works it will only be a $90 mistake. (back to punching myself in the head).
Paul
Upvote 0
Paul
Upvote 0
Solution
You didn't have to re-install the firmware, all you need is to use the flashlight to navigate to Reset to factory default and the problem would've been solved.
Upvote 0
OK! Thanks, good to know. I'll try it on the old unit and see if works. Wound up getting a used CMU off of eBay.
Upvote 0
