- 2018 CX-5 Sport
The jug states that it is OEM for Mazda, and that it is SPOAT. It should be fine, right?
Link Super Tech Coolant
Do you know when Mazda switched the coolant? I had the newer coolant put into my 2016 last year but I'm trying to figure out if my 2019 has the old or new coolant.Just keep in mind that Mazda mixes their FL22 55/45, not 50/50, for enhanced corrosion protection ever since the TSB on the heater core issue.
Thanks. Unfortunately my 2019 is in the 58XXXX range so I have the 50/50.I believe it was April 2019 that the newer coolant was implemented on the assembly line. The attached TSB says CX-5s with VIN ending in 605884 or lower are affected and have the 50/50 FL22.
$26 a gallon for Mazda coolant? Price must have dropped. I've changed out my 2014 twice using Zerex Asian (pre-mix) because the Mazda coolant was ~$40 a gallon at the time and I was getting a bit fed up with Mazda's premium pricing on some items. I'd use it too at $26 a gallon.Why not just use the Mazda coolant? I paid $26 for a gallon at my local dealer, and I have the reassurance that it's the exact right formulation. It lasts so long anyway, I'm not worried about saving a couple of dollars.
Every time I read that I come away with one question.I believe it was April 2019 that the newer coolant was implemented on the assembly line. The attached TSB says CX-5s with VIN ending in 605884 or lower are affected and have the 50/50 FL22.
Senior moment, checked my records and I had the coolant changed at 52,000 in the 2019.Thanks. Unfortunately my 2019 is in the 58XXXX range so I have the 50/50.
With 64,000 miles probably a good point to swap it out.
The first nearby dealer did quote $40, so I called another one and they sold it to me for $26. At $40, I might have made a different decision.$26 a gallon for Mazda coolant? Price must have dropped. I've changed out my 2014 twice using Zerex Asian (pre-mix) because the Mazda coolant was ~$40 a gallon at the time and I was getting a bit fed up with Mazda's premium pricing on some items. I'd use it too at $26 a gallon.
I put SPOAT for Stabilized Phosphated Organic Acid Technology from what was printed on the bottle in the picture. The Zerex concentrate does seem best, can make the mix stronger than 50/50 and distilled water is cheaper than the water used in the 50/50 mixes. I see the concentrate for only $22.99 on Amazon.Not an expert on coolants, but isn't the spec PHOAT for Mazda or was that a typo? I wouldn't mix the OEM with anything but PHOAT like Zerex Asian that you can get at O'Reilly's. Is it dark green?
