Hearing a "whirring" noise for about a minute after turning car off-nothing seems to be running...happens all times-engine warm or cool
anyone else have this? Thanks!
its not the fuel pump.Fuel pump. They all do it, even my Pontiacs from 20 years ago did it.
We're talking about the whine, I thought?Its the throttle body as far as I know. Hear a final "flap/click" sound after 40-50sec and the noise is gone.
i think you are correct-i am putting my cupped hands over hpfp and pitch changes,then in series i hear 1 click,then 1 click near throttle body then 1 more click from relay box and its gone-just strange because i am around a few other cx-5's and i dont hear it-last nite i heard sounds like the pump was still running-grabbed a little screwdriver to put on top of solenoid but i guess the voltage was to low to feel the magnetism,if i really want to get nuts i could get tools to check fuel rail pressure or back probe the solenoid-still under warranty so this is why i am on the hunt,thanksits not the fuel pump.
Yea the Headlight issue/noise is a warranty item. Separate type of noise.
ok,i need to do a deepdive-headlites with fans? thats crazy....do they really cost 2k each?It's not the fuel pump. My CX50 H and my CX5 NA both make the noise. I think it's headlight fans. I don't see why it's a warranty issue, it's normal and they all do it for 5 seconds or so after you turn off the car.
Yes, the headlight assemblies do cost upwards of that amount. I had to have both headlight assemblies replaced on my '22 due to excessive rattling and buzzing (there is a TSB for this).ok,i need to do a deepdive-headlites with fans? thats crazy....do they really cost 2k each?
