Noise after CX-5 is turned off..?
Hearing a "whirring" noise for about a minute after turning car off-nothing seems to be running...happens all times-engine warm or cool
anyone else have this? Thanks!
fuel pump....huh...ok...strange...so it needs to be ready for the next cycle or something-sorry ...first car with a high pressure fuel system....i saw some videos online and most were headlight issue's...i would love to repost the small video i saw on this site....at the very end of it...you get a 2 second soundbite of what i hear-guess i could do my own little video as well
Yes, the headlight is also a possibility and is known issue. I've so far been lucky that my 2023 doesn't have it (knock on wood), even as I see several other 2023's failing. Make sure it's not coming from a headlight and if it is, take it in for a warranty replacement asap.
Fuel pump. They all do it, even my Pontiacs from 20 years ago did it.
its not the fuel pump.
Its the throttle body as far as I know. Hear a final "flap/click" sound after 40-50sec and the noise is gone.
Yea the Headlight issue/noise is a warranty item. Separate type of noise.
I was referring to the whirring/buzzin noise from the engine compartment upon engine shutdown. For about 1 minute, then a click/flap closing and no more buzzing. My Turbo CX5 does that.
Even our V6 Turbo Diesel Mercedes has the fuel pump sound.
This is really easy to hear if you're in a garage.
Which fuel pump are you talking about?
Only the one in the fuel tank is electric. The buzzing noise is in the engine compartment.
